Angle gauge on base of distributor?
#2484690
04/18/18 04:36 PM
04/18/18 04:36 PM
Posts: 4,693 Wichita
GY3
Wichita
Trying to come up with a simple way to know how many degrees I've moved distributor vs. using timing light every time.
I currently mark the distributor and the block where I know, at a glance, where 36° total is for me.
Since I started playing with nitrous, I retard different amounts for different tuneups.
I thought about using the base of a torque angle gauge or degree wheel and some way mounting it to flat base of the distributor. I googled 360° 2.25" angle gauge and didn't come up with much.
Yes, I know there are MSD controllers that allow you to retard/advace but was trying to keep it old school.
Any ideas?
Re: Angle gauge on base of distributor?
[Re: Neil]
#2484697
04/18/18 05:03 PM
04/18/18 05:03 PM
GY3
Wichita
Cool! I've never seen one of those.
[Re: AndyF]
#2484757
04/18/18 07:29 PM
04/18/18 07:29 PM
GY3
Wichita
Shouldn't be too hard to fabricate something. I mark my crank trigger brackets with a dimple every 2 degrees so a person and adjust the timing without a timing light. Yep, just looking for ideas at this point.
[Re: GY3]
#2484774
04/18/18 07:56 PM
04/18/18 07:56 PM
BradH
Cool! I've never seen one of those. Yep, I thought I recalled seeing those at some point. I'd like to have something like that for my car, too.
[Re: Neil]
#2484782
04/18/18 08:11 PM
04/18/18 08:11 PM
RapidRobert
I seen it when I was employed there but I never thought (at the time) to see about modding it for us.
[Re: Porter67]
#2484791
04/18/18 08:36 PM
04/18/18 08:36 PM
RapidRobert
^^^ Ding ding ding we (may) have a winna. time it/make your reference dots/should all be good.
[Re: Porter67]
#2484793
04/18/18 08:37 PM
04/18/18 08:37 PM
GY3
Wichita
You would be amazed what a simple red or black sharpie dot on the lower edge of the dizzy where it sits on the block and then one on the block. A sharpie mark can last for several years.
No need to overthink the simple for no more then your doing.
Have a black dot on your dizzy, match it to a black dot on your block for na, and a red dot for spray. Check one time a year with a timing light for chain stretch.
That is what I'm doing now and have done for quite a while. Not a problem for one or two points but with multiple different settings for different N2O jettings, was thinking I could do it better...
[Re: GY3]
#2484798
04/18/18 08:48 PM
04/18/18 08:48 PM
RapidRobert
for multiple points it would seem like a (very) good addition. I used to run around in Wichita decades ago (I lived down on hydraulic avenue) back when BTK was doing his thing.
[Re: RapidRobert]
#2484822
04/18/18 09:33 PM
04/18/18 09:33 PM
GY3
Wichita
for multiple points it would seem like a (very) good addition. I used to run around in Wichita decades ago (I lived down on hydraulic avenue) back when BTK was doing his thing. I live near Andover now but back before he got caught, we discovered my son went to a private daycare less than a 6 houses down from where BTK lived!
[Re: Porter67]
#2484824
04/18/18 09:36 PM
04/18/18 09:36 PM
GY3
Wichita
MSD parts play well with mopar dizys, you could run a newer box and pull it out with a laptop or with a older box like a 6al you could easily hide the lil msd chipped retard box.
Alot of fun for not alot of money is the nos mini controller with alot of features since your going deeper into it. Ramping it is a bit turbo like power.
It looks like your hooked, be careful, it only takes one mistake to get bit. Yep, already have an older analog 6AL box hidden under the battery tray but triggered by a Mopar electronic distributor. I also have a Leash single stage board for the nitrous. May just buy the #8680 MSD adjustable timing contoller...
[Re: Porter67]
#2484841
04/18/18 10:08 PM
04/18/18 10:08 PM
GY3
Wichita
I did a seperate, dedicated fuel cell mounted up front with an electric pump to feed only the fuel solenoid. I played with the 100 shot jetting first and everything went well, bumped to 150 shot and it is a riot! I have jets for up to 250 but really should change out the plugs for colder for anything past what I'm doing now. Lots of fun on the street! I used to be able to hook from a roll in first at 30-40 mph with the ET Street Pro's but now it squirts sideways and MOVES OUT once I bang 2nd!
[Re: GY3]
#2484927
04/19/18 01:46 AM
04/19/18 01:46 AM
Posts: 43,251 Bend,OR USA
Cab_Burge
for multiple points it would seem like a (very) good addition. I used to run around in Wichita decades ago (I lived down on hydraulic avenue) back when BTK was doing his thing. I live near Andover now but back before he got caught, we discovered my son went to a private daycare less than a 6 houses down from where BTK lived! Who is BTK?
[Re: Cab_Burge]
#2484933
04/19/18 02:30 AM
04/19/18 02:30 AM
RapidRobert
Dennis Rader the Wichita Kansas serial killer (BTK-bind/torture/kill)
