Gasolin evaporate / return to tank from carb?
#2484561
04/18/18 11:37 AM
04/18/18 11:37 AM
Posts: 84 Norway
cudaerik
Norway
I have to crank for a long time to start the engine in my 70 Charger after it's been sitting for a few days. Why do the gasolin evaporate or return to the fuel tank? Running stock fuel tank and 5/16" fuel line, brand new Carter mechanical fuel pump, Edelbrock fuel filter before an brand new Edelbrock 800cfm carb.
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600) 1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600) 1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: Gasolin evaporate / return to tank from carb?
[Re: ScottSmith_Harms]
#2484565
04/18/18 11:46 AM
04/18/18 11:46 AM
Posts: 84 Norway
cudaerik
Norway
is it possible to add an electric pump only to only fill up the bowls and then switch it off and run the mechanical pump? will the mechanical pump be able to such the gasolin trough the electric pump?
[Re: cudaerik]
#2484611
04/18/18 02:00 PM
04/18/18 02:00 PM
Posts: 84 Norway
cudaerik
Norway
Thanks for the comments, sounds like an electric pump would solve the problem. what electric pump would hold up long term?
