Page 5 of 5 1 2 3 4 5
Re: Pro stock tech [Re: Alan Prusiensky] #2484530
04/18/18 10:48 AM
04/18/18 10:48 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I will be cheering for Alan at home in Oklahoma watching on All Access, but those of you at the Houston race should go by and personally thank Alan for taking the time to share information with us at Moparts.
Bill Lamb
Re: Pro stock tech [Re: dthemi] #2484628
04/18/18 02:35 PM
04/18/18 02:35 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted By dthemi
Anybody that's around Wj much knows his compliments are rare, and served in small doses lol.
Especially for guys who drive Jeeps. whistling
Re: Pro stock tech [Re: Alan Prusiensky] #2484755
04/18/18 07:25 PM
04/18/18 07:25 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Originally Posted By Alan Prusiensky
I wanted to start this so I can show Mopar what a mistake they are making. They think nobody likes pro stock. I know that is not true. I see so many Mopar pro stock fans at every race thanking me for sticking with it. So I will answer any questions you got on the engine,trans, clutch & setup.
I just wanted to say thanks for sharing....
Prostock has been, and probably always will be, my favorite class. Ever since I was a little kid, I knew I wanted to race in prostock. And specifically, in a Mopar. As time went by, I learned my way around some friends race cars and eventually was old enough to get my own....Been racing Mopars ever since. Mind you not prostock, just brackets and what ever the budget allowed for. Had plenty of cars over the years, but usually Cuda's....
I remember trying to learn everything there was to know about the secretive prostock group...Even got to hang out in the pits with a few of the Mopar prostocks at National trails a few times. I always loved seeing the Mopars kick ass.
Always appreciate it when racers share there stories...I still race, and yes, its usually in a Cuda or a Duster....And as you do, I wish there was more support for racers and manufacturers....Seems like this hobby is going to go thru a big change soon....
Keep up the good work Alan, and maybe we will bump into you one of these days.
Re: Pro stock tech [Re: Alan Prusiensky] #2487904
04/25/18 07:01 PM
04/25/18 07:01 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
One of the topics of conversation is the availability (or lack of it) of good blocks and to a lesser degree, good heads.
Is the availability of the pieces you use a potential problem or is there plenty of that stuff around now that you're the last guy standing? Is anyone using the basic components for anything other than Pro Stock or are they pretty much built for that application?
Re: Pro stock tech [Re: CMcAllister] #2488401
04/26/18 06:42 PM
04/26/18 06:42 PM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
I would be interested to know what a Pro Stock engine might have for cranking compression....
Also how many runs before the valve job would need attention typically?
Thank you!
Curator at Adams County Speed Shop
Re: Pro stock tech [Re: Alan Prusiensky] #2488408
04/26/18 06:55 PM
04/26/18 06:55 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
How much HP are you down compared to the top 5 I see your down almost 5 mph to the top cars
Re: Pro stock tech [Re: 340man4ever] #2488421
04/26/18 07:46 PM
04/26/18 07:46 PM
brisbane,australia
coletrickle Offline
coletrickle  Offline
brisbane,australia
[quote=340man4ever]I would be interested to know what a Pro Stock engine might have for cranking compression....
Not Pro Stock but comp eleminator in the 90's and it was 15 runs and it motor out for a freshen up.But it was the rings that were the issue.May have changed now with those fancy ring packs that are out there.
Re: Pro stock tech [Re: Alan Prusiensky] #2489128
04/28/18 05:14 PM
04/28/18 05:14 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Pro stock is the space program of drag racing
Re: Pro stock tech [Re: Alan Prusiensky] #2489256
04/28/18 10:27 PM
04/28/18 10:27 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Alan, do you guys run a timing curve on your ignition? Obviously, I'm not talking about a normal idle to 2,500 rpm curve. I was wondering if the ignition timing is varied on upper rpm levels (from launch rpm to shift point) or is piston speed at a point that it doesn't change much.
