I agree it depends on the application. The Spool motor mount itself is almost indestructible. But where and how it mounts to the K frame spool mount catch isn't so tough, it will give or pull through before the Spool mount fails.
But if your spool mounts are really , really old the rubber bushing can eventually give like anything else, but the cross bolt is captured unlike the bisket type mount that totally gives way. But even old, I don't think I have seen one give way yet, but I'm sure there are some. Now the bisket types, ive seen tons give way, even new ones with stock motors that were beat on.
