Torque strap question #2483749
04/16/18 06:00 PM
04/16/18 06:00 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Do you think it would be necessary or not to use a torque strap when using spool motor mounts?
Re: Torque strap question [Re: 1970RT] #2483758
04/16/18 06:13 PM
04/16/18 06:13 PM
Have someone sit in the car with the motor running and holding the foot brake and see how much the motor moves up towards the passenger side when you load the motor against the converter up to as much as you plan on doing that scope
Decide from that and go from there up
Re: Torque strap question [Re: 1970RT] #2483769
04/16/18 06:43 PM
04/16/18 06:43 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Depends on the application. Saturday night cruise car? No. 9 second, 3300#, stick shift car? Yes.
Re: Torque strap question [Re: 1970RT] #2483819
04/16/18 08:28 PM
04/16/18 08:28 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I agree it depends on the application. The Spool motor mount itself is almost indestructible. But where and how it mounts to the K frame spool mount catch isn't so tough, it will give or pull through before the Spool mount fails.
But if your spool mounts are really , really old the rubber bushing can eventually give like anything else, but the cross bolt is captured unlike the bisket type mount that totally gives way. But even old, I don't think I have seen one give way yet, but I'm sure there are some. Now the bisket types, ive seen tons give way, even new ones with stock motors that were beat on.
Re: Torque strap question [Re: 1970RT] #2483866
04/16/18 09:42 PM
04/16/18 09:42 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I had a different reason (Dart Sport 360, 727): the bigger exhaust system was too close to the floor, and rattled on WOT. Used wire braid to restrain engine movement, really helped without increasing NVH.
Boffin Emeritus
Re: Torque strap question [Re: polyspheric] #2483888
04/16/18 10:03 PM
04/16/18 10:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run a pair of them on my Rampage and on the
P-BODY.. cant hear them at all.. sure helps
on a launch.. both cars are SB one is a 416ci
the other 395ci
wave
