413 industrial block #2483537
04/16/18 12:01 PM
04/16/18 12:01 PM
an8sec70cuda Offline OP
I recently acquired a 1972 model 413 industrial engine supposedly out of a dump truck.
A few things I found on this engine have me wondering...
Some on the internet say these 413 "cold weather" blocks are just under-bored 440s, so you can supposedly take them out to 4.32" or + .060" possibly from there. I know I need to get it sonic checked, but has anyone verified this?
All I've read online says these came w/ gear drives and reverse rotating cams...this one has a double roller chain in it. Wonder if it has been gone through before or if it came this way?
Are these big cylinder heads and related parts (water pump setup) worth anything or should I just send em to the scrapyard? The shortblock is staying with me...especially since it has a forged crank (which is a 6 bolt flange). I have the short tail w/ drum brake 727 too.
I thought the heat shields b/t the block and exhaust manifolds were interesting.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 413 industrial block [Re: an8sec70cuda] #2483538
04/16/18 12:02 PM
04/16/18 12:02 PM
Heat shields
CHIP
Re: 413 industrial block [Re: an8sec70cuda] #2483539
04/16/18 12:03 PM
04/16/18 12:03 PM
Water pump setup and the trans
CHIP
Re: 413 industrial block [Re: an8sec70cuda] #2483551
04/16/18 12:45 PM
04/16/18 12:45 PM
P
Porter67 Offline
Porter67  Offline
P
There are many in my area that have been worked hard and can be bought for next to scrap prices. But if you didnt pay alot and the shortblock is sound it surly is seasoned well but not a bad thing.
You might run the heads and other parts on CL cheap before sending them to the metal yard.
The trans is good for parts, I thing the main case is like most 727-s and it might have some good parts in it if not worked too hard.
Just like with anything else if it ran coolant vs water most its life is a plus.
None the less with folks wanting crazy money for even a block if you bought it cheap your ahead in the end as most just cant past the stigma of buying an industrial motor to use as a base core.
Im a bit surprised to see a auto hooked to it. What year is it?
I would mag everything your going to reuse.
If you rip it apart soon, post further on how things look wear and tear wise.
Re: 413 industrial block [Re: an8sec70cuda] #2483560
04/16/18 12:57 PM
04/16/18 12:57 PM
I was planning on keeping it for myself since, like you said, using a 413 industrial motor for a buildup isn't what a lot of folks like to hear.
It's a '72 model.
I actually got a package deal...three 440s and this 413, all four w/ 727s attached. Too good a deal to pass up...guy was moving out of state and couldn't take them w/ him. Was a lot of fun loading these heavy suckers under a shed w/ a soft dirt floor using a cheap flimsy harbor freight engine hoist.
I won't likely tear it apart anytime soon. Well, except to remove the topend. Wipe some grease on the bores, wrap it up, and stick it on a pallet in the barn to save for a later date.
CHIP
Re: 413 industrial block [Re: an8sec70cuda] #2483583
04/16/18 01:43 PM
04/16/18 01:43 PM
Zumbrota,MN
als499 Offline
als499  Offline
Zumbrota,MN
You could build a hemi relatively cheap using this block, Stage V conversion heads and 426 rods and pistons.
Re: 413 industrial block [Re: an8sec70cuda] #2483585
04/16/18 01:49 PM
04/16/18 01:49 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Can you show a close up picture of the spark plugs on these heads.
They appear to be laid out like a 340 instead of the normal 383/440 style. Or maybe it is just the picture that makes them look at an angle and pointing up instead of from a 90 degree side.
Curious about the heads. What do the ports and chambers look like.
The manifolds appear to bolt on differently.
Old Geezer Racing
Re: 413 industrial block [Re: an8sec70cuda] #2483588
04/16/18 01:50 PM
04/16/18 01:50 PM
A727Tflite Offline
A727Tflite  Offline
Buddy of mine had a D-800 with the 413 and manual trans and two speed rear axle.
Was an enclosed car carrier he used for years.
My first trip in it was to head to Gainesville, had my car out back. We stopped for dinner the first night and as we walked away I looked back at the rig and noticed an orange glow under the front of the truck and thought it had caught fire. I ran back to the truck yelling and my buddy laughed and said it was just the glow of the exhaust manifolds.
They were bright red. That's why the heat shields are there.
Foot note - we lowered fuel consumption by adding a windage tray, flogging the carb and changing the timing. Managed to get it to - 5-1/2 mpg.
Re: 413 industrial block [Re: an8sec70cuda] #2483593
04/16/18 02:04 PM
04/16/18 02:04 PM
als499...I hear getting Stage V to make a set of those conversion heads is a challenge. You're right though, about the shortblock at least. You can find old school std. bore hemi pistons cheap.
Scatpack...they do point up and slightly in like a small block. These heads are different than normal BB heads w/ the extra extended water jackets around the exhaust ports...hence the manifolds bolting on differently. The intake bolts on the same and will work on standard heads so I'm told. They have sodium filled valves. The head is taller which means longer pushrods. The rockers look the same, but supposed to be different somehow.
I have not pulled a head off yet, but will post some pics when I do if you'd like.
Transman...got it UP to 5.5 mpg??? Wow, lol.
CHIP
Re: 413 industrial block [Re: an8sec70cuda] #2483597
04/16/18 02:08 PM
04/16/18 02:08 PM
I'm assembling a 1973 413 truck block now that I took in trade on assembling a customers pump gas pickup 440 motor that he had bought all the parts for the short block.
I sonic tested the 413 block and it was no where thick enough to bore to 4.320 safely tsk twocents
I had it bored to 4.250 and added a used Mopar brand 4.15 stroke crankshaft with the 2.375 rod journal sizes so I can put it in my 1963 Plymouth pump gas street car in the near futre, hopefully grin
This will be one of my old school junk parts build using a set of used 440 source heads that I took in trade, a set of custom Auto Teck pistons, a used set of Eagle Hemi rods with the big pins and so on wrench
I did reuse the crankshaft, I had it offset ground to BB Chevy rod sizes to 3.90 stroke for another pump gas build using a late model 440 block out of another 440 motor home take out wrench
I think the misinformation on those older 413 truck blocks was put on the internet by a keyboard "expert" runaway
I've sonic tested several of them (5+) and none of them where extra thick on the bores whiney shruggy The biggest I had any of them bored to was 4.250. IHTH thumbs
Re: 413 industrial block [Re: an8sec70cuda] #2483599
04/16/18 02:09 PM
04/16/18 02:09 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
IF you don't care, post up some pictures of the spark plugs and combustion chamber. I am intrigued by that design. Never ever saw it before. And I thought I had worked on every Mopar block ever made.
Old Geezer Racing
Re: 413 industrial block [Re: SCATPACK 1] #2483614
04/16/18 02:39 PM
04/16/18 02:39 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
the only time i every seen those engines in front of a torqueflite is in a
what is called the big A. a 3 wheeler that sprays chemicals on ag fields.
a machine about 10-12 tall
Re: 413 industrial block [Re: an8sec70cuda] #2483627
04/16/18 03:02 PM
04/16/18 03:02 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I can't see the sides of block to well because of shields, are there extra ribs, more than a stock 440? Early industrial blocks had these and much thicker clyinder walls. I had a 426 block out of a 40 ton crane, when bored 60 over the machinist said it was the only block that ever "sang" to him. Replaced my TMC 426 HP block. Maybe these newer ones are the thin wall blocks you hear about. Still an excellent purchase.
Re: 413 industrial block [Re: an8sec70cuda] #2483634
04/16/18 03:14 PM
04/16/18 03:14 PM
Cab...thanks for the heads up! I will definitely have it sonic checked before having it bored. Like anything else, there's a lot of conflicting info out there about these things. Probably b/c there aren't a lot of them around and most is hearsay.
Read where these are supposed to have the 6 pack rods...this one has LYs.
SCATPACK...I'll get some more pics for sure. Hope to get the heads off of it the end of the week when I have some free time.
Guess I'll run a craigslist ad for a few weeks to see if anyone wants the heads and stuff. If not, off to the melting pot they go. This stuff is so heavy it won't be worth shipping anywhere. Just the water pump weighs a ton.
dodger mope...lots of those type machines running around here, but all diesel. I'm sure they're all newer than what this would have been in though.
cudaman...I have not removed the shields yet, but there does appear to be more stiffening ribs on the side of this block. That's why I referred to it as a "cold weather" block, which is what I usually see them called here on Moparts.
CHIP
Re: 413 industrial block [Re: an8sec70cuda] #2483680
04/16/18 04:28 PM
04/16/18 04:28 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The vast majority of those came in motor home chassis. They were all automatics, the manual trans version is not as common as the auto for that reason even though most of the non motorhome apps were manual trans equiped.
The heads flow worse than a run of the mill SB head. Chambers look sorta like a 516 BB head but with tiny valves and huge space between the valves.
Re: 413 industrial block [Re: an8sec70cuda] #2483776
04/16/18 06:55 PM
04/16/18 06:55 PM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
I post this as a question and a response. We run a 413 block in our '63 N/SS Plymouth. It's bored .060 to make it 426". It is an industrial block with the extra webbing on the sides. Otherwise it's been built as a race engine from back in the day...12.2:1, Max Wedge heads and intake, two Carter 750's, and a big roller cam. The car runs in the 10.90 range.
That being said, my father and I got into a discussion just yesterday when I told someone that our engine was a 413 + .060. He said, "No, it's a 426!" If I remember correctly, weren't the '62 and early '63 cars 413's? I believe in mid '63 they went to 426". My question is, was the 426 a new casting, or were they 413's that were over-bored? Thank you in advance.
Re: 413 industrial block [Re: Tommy D] #2483806
04/16/18 08:06 PM
04/16/18 08:06 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
62"S WERE 413 63 WERE 426. 60 OVER 413 IS A 424 80 OVER 426. NO THEY WERE DIFFERENT CASTINGS
JAKES AUTOMOTIVE
Re: 413 industrial block [Re: an8sec70cuda] #2483849
04/16/18 09:18 PM
04/16/18 09:18 PM
organ
maximum entropy Offline
organ
i built a very mild street "440" for a guy, that turned out to be a 413 industrial punched out to 4.32. that thing had SCARY thin cylinder walls. it's still out there melting tires, but he is lucky in most all of his endeavors. i don't have any sonic numbers, i just felt the "thickness" by sticking a pinky into a water jacket hole. compared to a few other blocks i had laying around, it was downright frightening. good luck, is all i can say...
Re: 413 industrial block [Re: an8sec70cuda] #2483863
04/16/18 09:41 PM
04/16/18 09:41 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I talked to a guy at Spring Fling who just bought one of those shorty tail shaft 727's. He's building a 426 Hemi powered A100 pickup. He's mounting the engine behind the cab and using that trans and a super short drive shaft to the rear.
Re: 413 industrial block [Re: an8sec70cuda] #2484059
04/17/18 08:40 AM
04/17/18 08:40 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
When my dad still had the salvage , we use to get a lot of PA state trucks, the only gear drive 413 we found came out of a 68(?) C800.
all the others were chain.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
