??? on 90`s dakota rims #2483740
04/16/18 05:41 PM
04/16/18 05:41 PM
my own world
theraif Offline OP
theraif  Offline OP
my own world
looking at a couple for a semi daily driver maybe a project, why did they go with that bolt pastern and not stay with 5 0n 4.5 ? it would make rim choices easier realcrazy
may i assume i can get a different rotor for the front
what about the rear end
dare i say adapters
Re: ??? on 90`s dakota rims [Re: theraif] #2483744
04/16/18 05:49 PM
04/16/18 05:49 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
91 went to 6 on 4 1/2 inch pattern. Then dak went back to 5 bolts in 05, and durango in 04, but a larger pattern than 4 1/2". I thinks. Many changes on different makes lately. Trucks anyway, used to rarely change.
Re: ??? on 90`s dakota rims [Re: theraif] #2483913
04/16/18 10:31 PM
04/16/18 10:31 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Yep, 91 was the first year for the 6 bolt wheels. 91 through 96 can be converted to 5 bolt at the front by swapping the rotors. The rear can be changed from 6 bolt to 5 bolt by swapping in the 5 bolt axles from the same size rear end. Dakotas used a 7 1/4, and the 8 1/4 (also called an 8 3/8") in the early 5 bolt pattern years, and a 7 1/4, an 8 1/4 (8 3/8), and a 9 1/4 in the 6 bolt era. I have no idea what they did with the "new" 5 bolt wheels, but I suspect they used the full size truck stuff.
With the 97 model year, the front wheel bearing design and parts of the front suspension were changed making the swap to 5 bolt very difficult on the front. I have heard there were some issues concerning the axle "C" clips involved with some of the 9 1/4 axle swaps, but there hasn't been a clear understanding of what those issues are for sure. It seems some have had issues, and some have not.
The 6 bolt pattern Dakota was around for several years, there are a lot more wheel choices then there were years ago. Its also the same bolt pattern used on a Viper. Gene
