Speedo cable core re-lube #2483291
04/15/18 09:20 PM
04/15/18 09:20 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
My speedometer was getting twitchy so I disconnected both ends
and slid out the core. It all appears good to me, no kinks or
obvious abnormalities.
What kind of grease is best to use on the core when I put it
back in ? Does the kind of grease make much difference ?
Re: Speedo cable core re-lube [Re: hemienvy] #2483323
04/15/18 10:06 PM
04/15/18 10:06 PM
I wouldn't think it'd be a dealbreaker but your parts house will have a small tube of speedo cable specific grease
Re: Speedo cable core re-lube [Re: hemienvy] #2483327
04/15/18 10:14 PM
04/15/18 10:14 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Powdered graphite is the ticket...
Re: Speedo cable core re-lube [Re: 1E2C] #2483434
04/16/18 01:58 AM
04/16/18 01:58 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Graphite is what I've used.
If you read the internet many also say white lithium type grease works too.
What you don't want is any sort of oil. When it gets cold the oil viscosity will change enough to make the cable hang up and cause the needle to fluctuate. It goes away when the car gets warmed up, but still annoying.
Re: Speedo cable core re-lube [Re: Neil] #2483643
04/16/18 03:28 PM
04/16/18 03:28 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Thank you, Gents.
Right now there is some kind of lube on the core, not much
though. Kind of greasy feeling.
Graphite sounds best.
Re: Speedo cable core re-lube [Re: hemienvy] #2483653
04/16/18 03:46 PM
04/16/18 03:46 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
Are they lubed new as spare part? I installed mine (NOS), haven't driven the car yet, but I did not pull out the cable to see before putting in place. Making me wonder now if I should have "enhanced" before installing.
Re: Speedo cable core re-lube [Re: hemienvy] #2483733
04/16/18 05:27 PM
04/16/18 05:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Cable lube.
Re: Speedo cable core re-lube [Re: John_Kunkel] #2483752
04/16/18 06:03 PM
04/16/18 06:03 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
[s][/s]
Originally Posted By John_Kunkel
Cable lube.
Is the that "cable lube" a grease or powder?
Re: Speedo cable core re-lube [Re: Ramrod39] #2483793
04/16/18 07:31 PM
04/16/18 07:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's a liquid graphite.
