Lumpy power steering on 74 Fury #2483590
04/16/18 01:54 PM
04/16/18 01:54 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
We have replaced the entire front and rear suspension (Firm Feel)on the Great Race Bluesmobile in preparation for this years race. That included a steering box upgrade/overhaul to a Stage 1 setup by Firm Feel. We have not driven it much and this may have been going on and not noticed as we were fighting a collapsed front brake line. That is now resolved so I am putting some serious miles on it each week. I now notice a slight lump in the steering wheel at about 30 degree intervals going each way. Parked with engine running it seems OK. Car is drivable as is, I was just wondering if this is normal for the quick ratio stuff. Thanks Jake & Elwood
CALMED THE QUAKE!!!(AGAIN!)
Re: Lumpy power steering on 74 Fury [Re: Spyphish] #2483622
04/16/18 02:57 PM
04/16/18 02:57 PM
Chicago
PurpleBeeper Offline
Chicago
That does not sound normal. You might want to check the upper/lower bearings/bushings in the steering column. Also, look for some idler arm & pitman arm interference with the car sitting just to be sure.
It almost sounds like a "bumpsteer" situation, so you might want to check your alignment too. Has the car been lowered?
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Lumpy power steering on 74 Fury [Re: Spyphish] #2483624
04/16/18 02:59 PM
04/16/18 02:59 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
FOUND IT!!! The rally speedometer bracket was slightly touching the steering wheel collar. Slid the bracket in further, BADA_BING smooth operation. That is why we did not notice it before as I put the speedo in last week. That Firm Feel stuff is Great. See you between Buffalo and Halifax late June. Jake
