Re: Dyno Simulators and ignition timing [Re: mopar dave] #2483422
04/16/18 01:33 AM
04/16/18 01:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By mopar dave
Thats what i'm talkin about. Mapping timing for every 500 rpm increase til max power. Isn't that what the OEMs are now doing and for each individual cylinder as well. Not sure anyone has done this on a Big Block mopar though. I'm happy just locking out for now, but just wonder how much power is lost thru the rpm range with fixed timing.
IF you gain it would be very little being you
have a locked dist.. if you had a vac adv dist
it would be adding timing on light throttle
and it can get up into the 50* range
wave
Re: Dyno Simulators and ignition timing [Re: MR_P_BODY] #2483496
04/16/18 10:02 AM
04/16/18 10:02 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Don't know what i'm gonna do yet. My MSD doesn't have a vac can, but i am looking a getting a different distributor. think i'll just leave it alone locked out for now. Thanks Mike
Re: Dyno Simulators and ignition timing [Re: mopar dave] #2483502
04/16/18 10:33 AM
04/16/18 10:33 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
The Chrysler tach drive will get you pretty close to that. Whether it shows as a flat line or a slight rise intiming will depend on two things. One, adjustment of the secondary spring perch. The other, speed of the ECU's electronics and other factors that may slow the firing time.
That SB unit that I showed the plot for was tested on a SUN 404 with an amplifier box. That box is pretty slow. Still flatlined.
Re: Dyno Simulators and ignition timing [Re: Mattax] #2483550
04/16/18 12:45 PM
04/16/18 12:45 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks for that linc. Looks like chrysler knows what needed and i just need to lock timing at 35* without losing any timing thru rpm increase.
