what post filter #2483161
04/15/18 05:12 PM
04/15/18 05:12 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
have a magnafuel 500 pump. most of the filters don't show flow #'s carbureted
Re: what post filter [Re: plycuda] #2483164
04/15/18 05:19 PM
04/15/18 05:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Look at the micron rating
wave
Re: what post filter [Re: plycuda] #2483215
04/15/18 06:55 PM
04/15/18 06:55 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
I understand the micron rating but if it only flows 50gph its worthless on a 500gph pump. just wondering what anyone was using.
Re: what post filter [Re: plycuda] #2483243
04/15/18 07:59 PM
04/15/18 07:59 PM
NY usa
540challenger Offline
NY usa
Never heard of needing x amount of flow from a filter only went by micron rating, usually the pump will recommend a filter to match the pump.
Re: what post filter [Re: 540challenger] #2483271
04/15/18 08:55 PM
04/15/18 08:55 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
because its micron is what ever doesn't mean it flows the same depending on surface area. a 2" long and a 8" long filter will filter the same micron but will flow way more. don't understand why most don't show flow #'s.
Re: what post filter [Re: plycuda] #2483273
04/15/18 09:02 PM
04/15/18 09:02 PM
jersey
Spaceman Spiff Offline
jersey
What is the flow rating of your fuel line....
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: what post filter [Re: plycuda] #2483289
04/15/18 09:18 PM
04/15/18 09:18 PM
Cab_Burge Online work
Cab_Burge  Online Work
Buy the biggest size 100 micron fuel filter you can get up work
Your right about the fuel flow, smaller actual filter area won't flow the same GPM as the biggest one will with the same size micron ratings shruggy
Re: what post filter [Re: Cab_Burge] #2483302
04/15/18 09:32 PM
04/15/18 09:32 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
looks like the pump has a 150 micron built into it. I'm having a problem with my needle and seat flooding so I wanted to put in a post filter, but didn't want to kill the flow.
Re: what post filter [Re: plycuda] #2483338
04/15/18 10:26 PM
04/15/18 10:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If your flooding you need to adjust the regulator
not choke the flow
wave
Re: what post filter [Re: MR_P_BODY] #2483339
04/15/18 10:31 PM
04/15/18 10:31 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
I have 5 pounds going to the carburetor
Re: what post filter [Re: plycuda] #2483341
04/15/18 10:34 PM
04/15/18 10:34 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
I never said I was trying to choke the flow. I'm trying not to choke the flow by getting a good filter
Re: what post filter [Re: plycuda] #2483346
04/15/18 10:45 PM
04/15/18 10:45 PM
jersey
jersey
what is your engine combo, that requires a 2,000hp rated pump??
Re: what post filter [Re: plycuda] #2483362
04/15/18 11:10 PM
04/15/18 11:10 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
If your having flooding problems with 5 psi and have cleaned the needle and seat and still have a problem , you have a damaged set. It will continue to give you problems. Replace it or both.
Re: what post filter [Re: Spaceman Spiff] #2483363
04/15/18 11:12 PM
04/15/18 11:12 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
its a slant 6 with 4 500hp foggers
Re: what post filter [Re: plycuda] #2483367
04/15/18 11:29 PM
04/15/18 11:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Keep looking.. there are plenty of filters with
a flow rating.. also your pump is way over kill
wave
Re: what post filter [Re: MR_P_BODY] #2483368
04/15/18 11:40 PM
04/15/18 11:40 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
why is everybody worried about my pump and what my combo is. how do you know its overkill. what do I have do you know I asked a simple question
Re: what post filter [Re: plycuda] #2483420
04/16/18 01:25 AM
04/16/18 01:25 AM
rowin4 Offline
rowin4  Offline
Well that being said , you probably got all the information your going to get.
Re: what post filter [Re: plycuda] #2483464
04/16/18 05:31 AM
04/16/18 05:31 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I used the KRC 100 micron screen type filter as a pre-filter when I had the in-line EFI pump. Not sure on flow, but large filter area.
https://www.summitracing.com/parts/krc-4708bk/overview/
On the Charger when i had a carb, I used the Mallory 500 filter. It is a 40 micron filter, but costs $200
https://www.summitracing.com/parts/maa-29246/overview/
Re: what post filter [Re: plycuda] #2483475
04/16/18 08:26 AM
04/16/18 08:26 AM
jersey
jersey
It’s because people are trying to help you.
But with your attitude, don’t be surprised if you don’t get any.
Re: what post filter [Re: plycuda] #2483507
04/16/18 10:54 AM
04/16/18 10:54 AM
NY usa
NY usa
Again never picked a fuel filter by flow just microns, now if u need more flow u up your fuel line size. Then u pick a filter with the correct microns and size to match your line and use a 40 microns 6 AN filter is going to flow less then a 40 microns 10 AN filter.
