TRICK FLO VALLEY PAN #2483331
04/15/18 10:17 PM
04/15/18 10:17 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Usable with any cylinder head iron or aluminum(Eddy, 440 Source, etc)?
Re: TRICK FLO VALLEY PAN [Re: A/MP] #2483384
04/16/18 12:09 AM
04/16/18 12:09 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
got it on my Source heads , used Andy's batwing gasket holders .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: TRICK FLO VALLEY PAN [Re: A/MP] #2483385
04/16/18 12:09 AM
04/16/18 12:09 AM
AndyF Offline
AndyF  Offline
Not really. Those solid valley plates are designed for extended runner heads like the Indy or TF 270.
If you use a billet plate with a normal head then you need something like the batwings I make to provide a seal.
