Anybody using air bag suspension kits? #2483270
04/15/18 08:50 PM
04/15/18 08:50 PM
RI Deep in the rust belt
chargervert Offline OP
I am building a Daytona racecar,that I want to use on the track and street. The car has a Loughlin stock car chassis in it. I have been trying to come up with a way to try to make the car user friendly on the street and track. The car sits too low now with the coil springs to really drive it on the street. I was thinking about an air bag conversion,so I would be able to adjust the ride height for both street and track use. I could always remove the air ride kit and reinstall the coil springs for serious track use. Does anybody offer a good all aroung kit for replacing coil springs. I will need to gain about 4 inches of ride height to operate the car on the street. Am I crazy thinking air bags may be the way to go,or should I just go with taller tires and coil springs for street use? Any suggestions would be appreciated. Thanks Pete
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Anybody using air bag suspension kits? [Re: chargervert] #2483307
04/15/18 09:42 PM
04/15/18 09:42 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
You probably need to contact someone like Ridetech about your situation since you are dealing with non oe based stuff. Plan on some back and forth with them on info like lengths, weights, mounts etc.
Carl Kessel
Re: Anybody using air bag suspension kits? [Re: CKessel] #2483313
04/15/18 09:48 PM
04/15/18 09:48 PM
Thanks,I was just looking at Ridetechs website. They say that they have expert techs available to talk directly to you if needed. That may be the direction I need to go for this.
Re: Anybody using air bag suspension kits? [Re: chargervert] #2483545
04/16/18 12:30 PM
04/16/18 12:30 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I would suggest contacting Laughlin to get their spring dimensional spec that are built into the chassis such as stock style 5.5" or coil over style 2.5" as well as the preferred height; (864) 963-6022. With that info, then a call to Ridetech to see what products are compatible with the physical layout of your chassis.
I wouldn't be concerned with using a bag set up on a streetable track day car. The Ridetech systems are pretty advanced now and will allow not only just ride height adjustments but can be dialed in with various spring rates from the driver's seat while underway.
Re: Anybody using air bag suspension kits? [Re: chargervert] #2483553
04/16/18 12:51 PM
04/16/18 12:51 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
One advantage of the air system would be if you are getting old and creaky, you can raise/lower it to make it easier to get in and out of. Don't know about you but I'm not as limber as I used to be.
Carl Kessel
Re: Anybody using air bag suspension kits? [Re: TC@HP2] #2483636
04/16/18 03:18 PM
04/16/18 03:18 PM
Thanks very much for the info, that is the way to go. The only other concern I have is heat from the brakes near the air bags. I may have to fabricate shields and brake cooling ducts for them.
Re: Anybody using air bag suspension kits? [Re: CKessel] #2483640
04/16/18 03:20 PM
04/16/18 03:20 PM
Lol,then all I will need is a chair lift to plop my old azz in the seat!
