Deck height - crank centerline #2482978
04/15/18 11:40 AM
04/15/18 11:40 AM
Keymar, MD
DusterKid Offline OP
Keymar, MD
What tool are you guys using to help find the center of the main bore so you can check the block deck height? Did anyone make one on their own?
Re: Deck height - crank centerline [Re: DusterKid] #2482988
04/15/18 11:58 AM
04/15/18 11:58 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
For block height..If you are good at measuring you can use a mic and a small pin inside the main bore, then do the math. Take your time and make sure its seated properly. It's probably not how a "shop" would do it, but if its done right, well, it will be right. No fancy fixtures.
Re: Deck height - crank centerline [Re: Hot 340] #2483017
04/15/18 12:39 PM
04/15/18 12:39 PM
Suburb of Chicago, IL
BCFKody Offline
BCFKody  Offline
I get the math. (Measurement + 1/2 the main bore dimension = deck height). But I don’t understand what you mean by a “small pin.” Also, are 10-11 in. Micrometers available? Or are you using something else?
Re: Deck height - crank centerline [Re: BCFKody] #2483025
04/15/18 12:52 PM
04/15/18 12:52 PM
a piece of round steel stock cuz with the mike being flat & the bore being round the mike will not sit down flat on the rounded surface.
Re: Deck height - crank centerline [Re: DusterKid] #2483032
04/15/18 12:58 PM
04/15/18 12:58 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
There is also a deck height mic available that doesn't have the full round beam like a regular mic. Don't remember who makes them, though.
[image][/image]
Re: Deck height - crank centerline [Re: BCFKody] #2483042
04/15/18 01:07 PM
04/15/18 01:07 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
pin size can be arbitrary..1/4 would work..see pic above
Re: Deck height - crank centerline [Re: Hot 340] #2483048
04/15/18 01:20 PM
04/15/18 01:20 PM
You could use a round pin & a tape (dont use the slotted chrome hook on the end) & several helpers which will get you "close" & purchasing that big of mike will be expensive unless you plan alot of use to get your moneys' worth. what I would suggest is putting the block belly up in the back of your pickup & driving to the machine shop & have/pay them to come out & take a measurement which would take several minutes & for sure call ahead & schedule a time (& hopefully you have a shop close by).
Re: Deck height - crank centerline [Re: DusterKid] #2483058
04/15/18 01:39 PM
04/15/18 01:39 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I used a 12" Mitutoyo caliper similar to the method of Hot 340 except no pin.
Floyd Lippencott IV
Re: Deck height - crank centerline [Re: mr_340] #2483083
04/15/18 02:27 PM
04/15/18 02:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I did my last block just like this.. worked
great
wave
Re: Deck height - crank centerline [Re: DusterKid] #2483084
04/15/18 02:27 PM
04/15/18 02:27 PM
A727Tflite Online content
A727Tflite  Online Content
Is there a reason you can't throw a crank and piston/rod assembly in a bore and check it that way? Pretty much every aftermarket set of pistons has a CD within a .001" and a set of rods made by a good company have about the same C to C distance. Throw the same piston/rod in each corner and you know if the decks are parallel while you are at it.
No special tools, and more accurate than a tape measure and straight edge.
Re: Deck height - crank centerline [Re: A727Tflite] #2483094
04/15/18 02:56 PM
04/15/18 02:56 PM
iagree
Stock rods lengths can vary a bunch, I've seen 426 M.W. rods have .008 differences in the center to center lengths puke shruggy
another thing to keep in mind on stock cranks is having the rod journals exactly 90 degrees away from each other at the top and bottom of the stroke, lots of them don't runaway
Lots of errors on most mass produced parts in our cars whiney
Re: Deck height - crank centerline [Re: DusterKid] #2483130
04/15/18 04:17 PM
04/15/18 04:17 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I usually use a 12" caliper as well, but they are not as precise as a micrometer. When using a micrometer, you can get a .2500 ball with a rubber holder for the anvil of the micrometer. That makes it easy and accurate.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Deck height - crank centerline [Re: DusterKid] #2483136
04/15/18 04:22 PM
04/15/18 04:22 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Here's a micrometer for you. Then you can do it yourself for many years.
mike
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Deck height - crank centerline [Re: DusterKid] #2483140
04/15/18 04:26 PM
04/15/18 04:26 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
I use a 12" caliper and do the math, but I don't think it's perfectly accurate. it will get you pretty darn close.
Re: Deck height - crank centerline [Re: DusterKid] #2483200
04/15/18 06:20 PM
04/15/18 06:20 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Remember that the main bearing bore (as shown) is not the journal size, and not listed frequently.
Some bearing catalogs list the actual bearing OD, but that may not include crush.
Doing the same measurement using the actual journal in place removes this variable, instead subtract 1/2 of the measured journal OD (duh).
Boffin Emeritus
Re: Deck height - crank centerline [Re: A727Tflite] #2483236
04/15/18 07:43 PM
04/15/18 07:43 PM
Keymar, MD
Keymar, MD
I have a std block and want to bore it .030 over. I'm thinking of going stroker and looking at pistons from dish to flat tops. Some are 2.05 to 2.067 compression height. I'd like to know my deck height so I can figure out which pistons will do what I want to be able to do. I'd like to start out around 10.1 compression but have the option to increase it with a thinner head gasket if/when I want to go faster. Can't stick a .030 over piston in a std bore block.
Re: Deck height - crank centerline [Re: DusterKid] #2483292
04/15/18 09:21 PM
04/15/18 09:21 PM
Every original stock Mopar V8 block I've taken apart and had blueprinted was way off on the stock deck heights, a lot taller than the NHRA specs. call for work
I've seen them tapered from front to back also shruggy
My main message is count on having your block deck cut to get it close to stock blueprint heights scope
Re: Deck height - crank centerline [Re: polyspheric] #2483299
04/15/18 09:29 PM
04/15/18 09:29 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
or mic the bearing bore of the block and add 1/2 of your dimention.
Re: Deck height - crank centerline [Re: DusterKid] #2483347
04/15/18 10:45 PM
04/15/18 10:45 PM
New York
polyspheric Offline
polyspheric  Offline
New York
True, that. Almost every data point is looser than called out.
Boffin Emeritus
