7290 u-joint issues #2482786
04/14/18 11:19 PM
04/14/18 11:19 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Headed back from track early with a friend of mine- broke the u-joint straps .
Ladder bar car, 512- pinion angle good .
Anyone know of better straps than the standard u- bolt style from Mancini etc?
Thanks.
Re: 7290 u-joint issues [Re: RustyM] #2482826
04/15/18 12:22 AM
04/15/18 12:22 AM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Get billet straps. I believe summit has them.
Re: 7290 u-joint issues [Re: RustyM] #2482829
04/15/18 12:23 AM
04/15/18 12:23 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I would upgrade to a billet yoke with the heavy duty thru bolt straps.
68 Barracuda Formula S 340
Re: 7290 u-joint issues [Re: RustyM] #2482832
04/15/18 12:25 AM
04/15/18 12:25 AM
Something is wrong other than the straps, they are there to hold the U joint back into the yoke solidly, not to take any of the load from the U joint or driveshaft scope
Yukon sells replacement billet aluminum yoke that comes with U bolts instead of straps for the 8 3/4 rear ends, just like the Mopar stock Dana 60 steel 1330 yokes have scope
Re: 7290 u-joint issues [Re: RustyM] #2482834
04/15/18 12:27 AM
04/15/18 12:27 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I would take a close look at your yoke. The majority of the u joint cup should be a snug fit in the yoke. The hold down strap is for exactly that, to hold it down. The strap doesn't really take any force. Do you have straps with bolts? I used Moroso aluminum caps for a while. The threaded u joint straps, I'm not sure what upgrade parts there are.
[image][/image]
Re: 7290 u-joint issues [Re: RustyM] #2482845
04/15/18 12:50 AM
04/15/18 12:50 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have had that happen, found the yoke had spread. Took me a few u joints to figure what the problem was.
Re: 7290 u-joint issues [Re: RustyM] #2482858
04/15/18 01:17 AM
04/15/18 01:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I will bet your U-joint angle is off.. I run the
simple little straps with the 4 small bolts..
never broke any of that... thats with a 1.19
60' on a alum 8 3/4 rear
EDIT
Or your ladder bar angle is off(pinion angle)
wave
Re: 7290 u-joint issues [Re: RustyM] #2482867
04/15/18 01:35 AM
04/15/18 01:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks.
If you look at the design you will see that the
cups go into the yoke OVER half way... that way
all the load is on the yoke.. the bolts or straps
are there to just keep the joint from falling out
wave
Re: 7290 u-joint issues [Re: MR_P_BODY] #2482940
04/15/18 07:32 AM
04/15/18 07:32 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I kept having trouble last season with a 7290 yoke. I used loc-tite on the bolts, torqued properly, etc. I kept breaking one strap bolt and then carnage...
Once I got that end fixed with a 1350 yoke and u-bolts, I broke the 7290 FRONT slip yoke! shock
I finally just ordered a new Strange shaft with 1350's at both ends!
According to my Virtual dyno, my engine makes 687 ft/lbs. @ 3450rpm. Couple that with its obesity and drag radials and it tends to be hard on driveline parts!
'63 Dodge 330
11.19 @ 121 mph
Re: 7290 u-joint issues [Re: RustyM] #2483011
04/15/18 12:28 PM
04/15/18 12:28 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
the billet style yoke with the spicer u-bolts is the best solution - those billet caps are actually worse than the stock straps - i would be looking at angle to make sure it is right
Re: 7290 u-joint issues [Re: DoubleD] #2483026
04/15/18 12:53 PM
04/15/18 12:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is true.. the fancy looking caps are a big
problem.. if you lift the car most of those caps
rub on the yoke.. that is bad.. your flexing
the cap.. you could be causing a vibration at
the rear cap
wave
Re: 7290 u-joint issues [Re: RustyM] #2483028
04/15/18 12:56 PM
04/15/18 12:56 PM
sgcuda Offline
sgcuda  Offline
If you are breaking straps and bolts, the load isn't staying on the yoke. I think your yoke is spread or worn out, u joint cup is walking off under load.
[image][/image]
Re: 7290 u-joint issues [Re: RustyM] #2483088
04/15/18 02:36 PM
04/15/18 02:36 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
.....and the torque on those little bolts isn’t much. You can stress the cap which can cause issues too.
Re: 7290 u-joint issues [Re: RustyM] #2483668
04/16/18 04:12 PM
04/16/18 04:12 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
I’m going to run over and check his pinion angle some time this week.
Fwiw- the one that broke looks like garbage metal- looked cast at first!
Looked at under magnifying glass - just really poor steel .
Going to put s mic night n his yoke saddles as well.
Re: 7290 u-joint issues [Re: RustyM] #2483694
04/16/18 04:36 PM
04/16/18 04:36 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I agree with all above, never broke one myself racing. Did brake one trying to get car on trailer with unwelded, but u-bolts tight, spring perches. U-bolts couldn't keep the axel from over rotating and, snap.
Re: 7290 u-joint issues [Re: RustyM] #2483759
04/16/18 06:17 PM
04/16/18 06:17 PM
Buy one of the best U joints you can get for future abuse grin Once you get it try removing one cup, or both, and press it into your current yoke to see how it fits, if it is sloppy and doesn't press and stay in their on its own then replace the yoke up scope
Let us know what you find work That feed back will help others on here in the future thumbs
