Quick Fuel 4150 question
#2482274
04/13/18 07:24 PM
04/13/18 07:24 PM
Posts: 1,462 Martinsville, IN
cdwmotorsports
Martinsville, IN
Does any Holley 4150 dual feed fuel line fit these? I have the BDQ 850 Quick Fuel carb and don't see anything for it specifically, however I am not wanting to order a fuel line just to return it.
eBay-cdwmotorsports
Re: Quick Fuel 4150 question
[Re: cdwmotorsports]
#2482305
04/13/18 08:35 PM
04/13/18 08:35 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
You could always call quickfuel and ask them
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
#2482550
04/14/18 01:09 PM
04/14/18 01:09 PM
Posts: 2,094 central texas
krautrock
central texas
run a flexible one like this, get a name brand one if that's your thing... be sure and pull the allen screw out of the port for the gauge hookup and put some thread sealant on it. ebay fuel line
#2482745
04/14/18 09:46 PM
04/14/18 09:46 PM
cdwmotorsports
Martinsville, IN
Cause that's what I used. No real reason why, all of my line is 8AN except the 10AN feeding the pump
eBay-cdwmotorsports
#2483156
04/15/18 05:01 PM
04/15/18 05:01 PM
BradH
I know the bowl fittings are 7/8x20 I was wondering about the width It can & does vary depending upon the type of fuel bowls being used. The early (standard) Holley bowls and the common less expensive aluminum bowls used on some QF and others' carbs are the same distance between fuel fittings. The later Holley Ultra H/XP aluminum and QF's "Fuel Chute" bowls are spread farther apart between fitting due to increasing their fuel volumes. The Holley Ultra H/XP and QF "Fuel Chute" bowls don't use the traditional 7/8 x 20 fittings, either, IIRC.
