Heat riser kit #2482526
04/14/18 12:20 PM
04/14/18 12:20 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Where to buy a heat riser kit for a 70 383 big block manifold?
Re: Heat riser kit [Re: 70 buzz] #2482554
04/14/18 01:15 PM
04/14/18 01:15 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
http://www.megapartsusa.com/proddetail.asp?prod=199%2DDR081
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Heat riser kit [Re: 70 buzz] #2482686
04/14/18 06:50 PM
04/14/18 06:50 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
dynamicrenovation.net is the manufacturer
Re: Heat riser kit [Re: 70 buzz] #2482789
04/14/18 11:23 PM
04/14/18 11:23 PM
Washington/Las Vegas
1971 Gran Coupe Offline
Re: Heat riser kit [Re: 70 buzz] #2482840
04/15/18 12:39 AM
04/15/18 12:39 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Anyone ever install one ?
Pretty straight forward or difficult
Siberian Huskies
Re: Heat riser kit [Re: bee1971] #2483072
04/15/18 01:59 PM
04/15/18 01:59 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Do you need everything or just pieces ?It's not hard if the original or the shaft is still there,a lot have been removed and had the holes welded shut and then it is a PITA. twocents
Re: Heat riser kit [Re: 62maxwgn] #2485514
04/20/18 11:23 AM
04/20/18 11:23 AM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Just the spring I think. Thought about doing the hole thing but wonder how hard the bushings for the pin to remove
Re: Heat riser kit [Re: 70 buzz] #2485694
04/20/18 05:29 PM
04/20/18 05:29 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Done a few, just remove valve inside manifold and tack weld shaft to keep it from rattling. The cars Ive done dont get driven in cold weather anyway so there was/is no need for it. Plus intake stays nice
Re: Heat riser kit [Re: gtx6970] #2486114
04/21/18 04:38 PM
04/21/18 04:38 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
. That will be the plan
