beehive vs. regular valvesprings #2482435
04/14/18 03:31 AM
04/14/18 03:31 AM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
i run rhs/indy heads (magnum)
1110 hughes springs 0.535 lift /boosted engine.
is there a upgrade spring for better valvecontrol ? have a few years on the hughes and when replacing why not upgrade ?
google about beehives and got a lot treads about better control with same pressure or even less.
anyone with real world experience?
Re: beehive vs. regular valvesprings [Re: Tobbe] #2482501
04/14/18 11:46 AM
04/14/18 11:46 AM
New York
polyspheric Offline
polyspheric  Offline
New York
I would if they're available with your spring rate + installed height + coil bind.
Boffin Emeritus
Re: beehive vs. regular valvesprings [Re: Tobbe] #2482565
04/14/18 01:29 PM
04/14/18 01:29 PM
AndyF Online content
AndyF  Online Content
Beehives are great if you can find one that fits your application. The beehive shape will also solve a lot of clearance issues with the rocker arms, especially on a SB engine.
Re: beehive vs. regular valvesprings [Re: AndyF] #2482641
04/14/18 04:49 PM
04/14/18 04:49 PM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
PAC has a 1286 spring thats close but i asked PAC and they say no ? and i haven't got a alternative
Re: beehive vs. regular valvesprings [Re: Tobbe] #2482754
04/14/18 10:05 PM
04/14/18 10:05 PM
New York
polyspheric Offline
polyspheric  Offline
New York
What data item is not suitable?
Boffin Emeritus
Re: beehive vs. regular valvesprings [Re: Tobbe] #2482760
04/14/18 10:13 PM
04/14/18 10:13 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Someone did a video on beehive springs. Absolutely no downside to using them. Spring frequency issues are just about nonexistent. No friction between inner and outer spring. Less weight. More clearance.
[image][/image]
Re: beehive vs. regular valvesprings [Re: Tobbe] #2482821
04/15/18 12:17 AM
04/15/18 12:17 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Choice of stock eliminator cars that came with single valve spring and that single spring must be maintained, as per rules. Many of the stockers are revving in excess of 6500-7500 rpms to make the power that they do.
Re: beehive vs. regular valvesprings [Re: Tobbe] #2483018
04/15/18 12:44 PM
04/15/18 12:44 PM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
