Fuel cell question #2482417
04/14/18 02:34 AM
04/14/18 02:34 AM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
I had/have a 15 gallon Triangle Engineering fuel cell that when I was removing an AN fitting from it the last three threads on the fitting destroyed themselves and the first three threads of the bung in the fuel cell.
I am now looking at replacements and saw these on eBay...
Fuel cell
My question is does anyone have experience with these? Worth the gamble or no? I really like the aluminum one I had but unless it can have the bad bung welded up I see no likelihood of saving it.
eBay-cdwmotorsports
Re: Fuel cell question [Re: cdwmotorsports] #2482419
04/14/18 02:46 AM
04/14/18 02:46 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
You should be able to get yours repaired provided you can find someone that can do it without blowing themselves up but it will likely be a wash money wise.
Kevin
Re: Fuel cell question [Re: cdwmotorsports] #2482434
04/14/18 03:25 AM
04/14/18 03:25 AM
A good brand of never seize is your friend on aluminum to aluminum fittings up
Re: Fuel cell question [Re: cdwmotorsports] #2482533
04/14/18 12:41 PM
04/14/18 12:41 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I do try to use antiseize on anything aluminum and my experience is often the same as the gentleman below:
Re: Fuel cell question [Re: 340Cuda] #2482548
04/14/18 01:07 PM
04/14/18 01:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Start blowing air through it.. once you cant
smell fuel you can cut off the fittings that
are galled and weld on new ones.. I weld alum
so its cheap for me.. if you have foam in it
pull that out before welding.. to weld the fittings
on is pretty quick
EDIT
Make sure the tank is clean.. no paint
wave
Re: Fuel cell question [Re: cdwmotorsports] #2482596
04/14/18 02:32 PM
04/14/18 02:32 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Can you drill and tap the bung for a larger size thread?
Doug
Re: Fuel cell question [Re: MR_P_BODY] #2482748
04/14/18 09:51 PM
04/14/18 09:51 PM
Martinsville, IN
Martinsville, IN
Doug
I have considered this but not sure what size I would go to, I think it has 10AN to maybe 1/2"NPT bungs in it already
LOL where were you 15 years ago? It did have thread tape on it but that clearly didn't help it
on is pretty quick
EDIT
wave
Its a bare Aluminum cell so I have considered this I will check it out further, thanks for all the help/suggestions guys.
eBay-cdwmotorsports
Re: Fuel cell question [Re: 340Cuda] #2482751
04/14/18 09:56 PM
04/14/18 09:56 PM
Martinsville, IN
Martinsville, IN
So do I not have to use thread sealer on the NPT side of these fittings? Fuel tank, regulator and pump are all aluminum bodied
eBay-cdwmotorsports
Re: Fuel cell question [Re: cdwmotorsports] #2482778
04/14/18 11:00 PM
04/14/18 11:00 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I didn't see where you mentioned the cell had ever had fuel in it. You could install a bulkhead fitting I suspect elsewhere and just plug and epoxy the partial threads left over and skip the welding solution.
The fuel cell link sounds/looks decent, almost priced too low, makes me wonder as if it's up to expected standards.
Who will go first? grin
Re: Fuel cell question [Re: cdwmotorsports] #2482783
04/14/18 11:16 PM
04/14/18 11:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is what I built for my Rampage.. its 17 gals
with 2 #10 fittings on the bottom, a vent and a
fuel gauge.. works perfect
wave
Re: Fuel cell question [Re: cdwmotorsports] #2482848
04/15/18 12:58 AM
04/15/18 12:58 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Both of my aluminum fuel cells have 1/2" NPT . A 1/2 " bulkhead fitting might be the best way to go. Tapping to 3/4"NPT would be questionable on how much material there would be left to tap.
Re: Fuel cell question [Re: jcc] #2483024
04/15/18 12:51 PM
04/15/18 12:51 PM
Martinsville, IN
Martinsville, IN
Has sold 104 of them and the reviews are all good.... dunno
eBay-cdwmotorsports
