I’m in the process of restoring my 70 cuda. With the 8 3/4 rear axle I found the wheel studs were all left handed. Is that correct? I thought only one side was left handed.
My assumption..Somebody "cherry picked" the right side axle from your axle and put it in their own.
Then jammed their old lefty in the one you bought to make it a "complete" rear axle assembly.
Simple fix,though.
Order new right hand threaded wheel studs.
RAYBESTOS # 4435B
Regardless,i would check the axle bearings' condition no matter what.
Hope this helps
