Left handed studs #2481556
04/12/18 11:53 AM
04/12/18 11:53 AM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
I’m in the process of restoring my 70 cuda. With the 8 3/4 rear axle I found the wheel studs were all left handed. Is that correct? I thought only one side was left handed.
Re: Left handed studs [Re: gregok] #2481583
04/12/18 12:19 PM
04/12/18 12:19 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Then somewhere in it's lifetime, someone put a left drum, or rotor on the right side, of the car.
Then as far as rears go, in the axle shaft, the same thing, for whatever reason, Who knows
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Left handed studs [Re: gregok] #2481709
04/12/18 04:21 PM
04/12/18 04:21 PM
MA
steve70 Offline
steve70  Offline
MA
Left side gets left hand thread
1970 Challenger T/A 4 speed
Re: Left handed studs [Re: gregok] #2481722
04/12/18 04:43 PM
04/12/18 04:43 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
My assumption..Somebody "cherry picked" the right side axle from your axle and put it in their own.
Then jammed their old lefty in the one you bought to make it a "complete" rear axle assembly.
Simple fix,though.
Order new right hand threaded wheel studs.
RAYBESTOS # 4435B
Regardless,i would check the axle bearings' condition no matter what.
Hope this helps
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Left handed studs [Re: 68Cbarge] #2481844
04/12/18 09:47 PM
04/12/18 09:47 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Yep, that helps a lot, kind of my thought too.
Re: Left handed studs [Re: gregok] #2481858
04/12/18 10:23 PM
04/12/18 10:23 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Are the the adjuster nut & associated parts still there or did they just swap in a LH side axle?
Re: Left handed studs [Re: Alaskan_TA] #2481897
04/12/18 11:17 PM
04/12/18 11:17 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
just swapped it in.
