Trick Flow head spark plug#'s #2481854
04/12/18 10:15 PM
04/12/18 10:15 PM
birdtracker Offline OP
Can anyone recommend a spark plug for a low deck with Trick Flow 270s? Thanks Birdtracker
Re: Trick Flow head spark plug#'s [Re: birdtracker] #2481859
04/12/18 10:24 PM
04/12/18 10:24 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
NGK-5671-A-9 in my 240's, but the last number is dependent on usage and fuel type.
Re: Trick Flow head spark plug#'s [Re: birdtracker] #2481979
04/13/18 02:08 AM
04/13/18 02:08 AM
What compression ratio and fuel type?
Re: Trick Flow head spark plug#'s [Re: Cab_Burge] #2482001
04/13/18 07:46 AM
04/13/18 07:46 AM
12.3-1 is the compression ratio. E-85 or possibly 110 race gas for fuel. Thanks for the info. Birdtracker
Re: Trick Flow head spark plug#'s [Re: birdtracker] #2482368
04/13/18 11:43 PM
04/13/18 11:43 PM
I'm going to assume that those heads use the 5/8 body .750 long spark plugs, if that is so I would start with a set of Autolite 3933 and see what they look like. My E85 motor has a little more compression than yours does and DOES NOT like the next step colder # 3932 plugs shruggy work
I've been told by several different E85 racers that E 85 does not need or like colder plugs shruggy
IHTHs thumbs
Re: Trick Flow head spark plug#'s [Re: Cab_Burge] #2482379
04/14/18 12:10 AM
04/14/18 12:10 AM
Cab: thanks for the info. I need some kind of starting point if you know what I mean. I did contact Summit and they recommended an E3 plug. Birdtracker
Re: Trick Flow head spark plug#'s [Re: birdtracker] #2482431
04/14/18 03:19 AM
04/14/18 03:19 AM
I wouldn't waste my time or money on a "trick" spark plug, my old airplane motor used what is referred to as "massive gap" spark plugs, it has two grounds that are set at .015 gap on each side, it runs two plugs per cylinders and dual magmeto with each mag firing one spark plug per cylinder. Max RPM is 2700 shruggy
Years ago their was another multiple ground electrode spark plug company around, I can't think of the name of it now due to it went B.K. from lack of sales, the proof is in the pudding work
Re: Trick Flow head spark plug#'s [Re: birdtracker] #2482605
04/14/18 02:57 PM
04/14/18 02:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
# 8 NGK.............. beer
