440 crank/rods in 400 block, better to cut block or crank? #2481355
04/11/18 11:58 PM
04/11/18 11:58 PM
GA
roadrunninMark Offline OP
GA
My friend wants to do a stroker motor with a 400 block. I have a 440 crank and rods. Is it better to align bore the 400 block than cut the crank down? What is the going rate to open up the 400 mains to accept it and how much does it need to be opened up? Do the 440 rods have any clearance issues? Which pistons should he go with?
Is there a guide out there somewhere when making this setup to go by?
Re: 440 crank/rods in 400 block, better to cut block or crank? [Re: roadrunninMark] #2481359
04/12/18 12:01 AM
04/12/18 12:01 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I've always heard it's better to cut the crank down.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 440 crank/rods in 400 block, better to cut block or crank? [Re: roadrunninMark] #2481369
04/12/18 12:15 AM
04/12/18 12:15 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Leave the meat in the block. Cut the crank.
Re: 440 crank/rods in 400 block, better to cut block or crank? [Re: roadrunninMark] #2481376
04/12/18 12:29 AM
04/12/18 12:29 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Crank
Re: 440 crank/rods in 400 block, better to cut block or crank? [Re: roadrunninMark] #2481409
04/12/18 01:08 AM
04/12/18 01:08 AM
AndyF Offline
AndyF  Offline
Boring the mains is a lot of work and requires some special tooling to recut the bearing tangs. Check with your local machine shop to even see if they can do it. I bet they'll tell you they can't.
Turning down the crank is an easier operation but it is getting harder to find anyone who can do the crank work. The mains need to be cut down and the counterweights need to be trimmed. Then you need to rebalance the crank.
One thing I don't like about turning down a 440 crank is that you are stuck running the big ugly Mopar rod journals. If you offset grind the rod journals to BBC size then you have even more machine work.
All of the machine work on the crank only makes sense if you have a local shop that works for cheap. If the shop charges more than $500 for the crank work then you might want to consider just ordering a new crank.
Re: 440 crank/rods in 400 block, better to cut block or crank? [Re: roadrunninMark] #2481472
04/12/18 04:55 AM
04/12/18 04:55 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
I am in the middle of this process now, with a forged 440 crank, offset ground to bbc rod journal, and cut the mains yesterday from 2-3/4 RB to 2-5/8 B journals. Next is to trim the counterweigths, and final is balancing. Those old cranks are non-twist forgings, and make bright sparks when grinding! Good old-school materials!
Re: 440 crank/rods in 400 block, better to cut block or crank? [Re: roadrunninMark] #2481562
04/12/18 12:02 PM
04/12/18 12:02 PM
New York
polyspheric Offline
polyspheric  Offline
New York
More chance of an expensive mistake cutting the block.
Boffin Emeritus
Re: 440 crank/rods in 400 block, better to cut block or crank? [Re: roadrunninMark] #2481673
04/12/18 03:10 PM
04/12/18 03:10 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Cut the crankshaft, the block needs all the help it can get.
Re: 440 crank/rods in 400 block, better to cut block or crank? [Re: Biginchmopar] #2481881
04/12/18 10:50 PM
04/12/18 10:50 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
everyone I know that runs the 440 crank in a 400 block always have the crank's cut.
