"O" ringing Hemi Head and Block #2480676
04/10/18 07:42 PM
04/10/18 07:42 PM
Parts unknown
590 Challenger Offline OP
Parts unknown
I’m looking to “O” ring my Hemi motor, A friend says he will throw it on his CNC and do it for free if I can get the specs. He is already decking the head and the block for me. I would have to assume all Hemi heads the rings are supposed to be placed in the same location so they can interchange from block to block and not be forever tied to a certain block? What size groove do we cut for the receiver groove? How deep? How deep in the head? I was told to use “D” shaped wire I the head it will seat much better, where do I get it? Thanks
Re: "O" ringing Hemi Head and Block [Re: 590 Challenger] #2480692
04/10/18 08:00 PM
04/10/18 08:00 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Is that even done anymore? Thought that was old school with the gaskets we have now. Sorry, I don't have any info on o ringing the heads.
Re: "O" ringing Hemi Head and Block [Re: 590 Challenger] #2480698
04/10/18 08:17 PM
04/10/18 08:17 PM
Parts unknown
Parts unknown
yeah, I had cometics in it, at 30 lbs of boost, I was told going to 45 pounds this year I have to O ring it
Re: "O" ringing Hemi Head and Block [Re: 590 Challenger] #2480711
04/10/18 08:44 PM
04/10/18 08:44 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Re: "O" ringing Hemi Head and Block [Re: 590 Challenger] #2480781
04/10/18 10:23 PM
04/10/18 10:23 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What makes go in this direction? Have you been having issues with head gaskets? I had o-rings,tigged them closed and milled the head.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: "O" ringing Hemi Head and Block [Re: TRENDZ] #2480823
04/10/18 11:34 PM
04/10/18 11:34 PM
Parts unknown
Parts unknown
Re: "O" ringing Hemi Head and Block [Re: hemi-itis] #2480827
04/10/18 11:39 PM
04/10/18 11:39 PM
Parts unknown
Parts unknown
I did melt the head and the block last year when the gasket went out, but it was cause from the car finally starting to hook, G force started to pull my fuel shut off lever off causing it to lean out. My friend that tours the country tuning Blown Promods says it should be mandatory at the new level
Re: "O" ringing Hemi Head and Block [Re: 590 Challenger] #2480943
04/11/18 09:09 AM
04/11/18 09:09 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
On my 500, the Indy heads had O rings in them, but not the block. It adds extra crush to seal the cylinders. I used a Flatout Gasket rubberized copper gasket. Sealed motor well at 14:1, but did have to add some extra silicone around the water ports. Probably because my deck surface was too rough on the block. Anyway, I don't think it is necessary to O ring both surfaces. Cut groove about 60-70% deep of wire diameter.
[image][/image]
Re: "O" ringing Hemi Head and Block [Re: 590 Challenger] #2480945
04/11/18 09:37 AM
04/11/18 09:37 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I would say you are making the right choice by going with o ringed copper. My personal opinion is to cut a receiver grove in the head, and the o ring in the block/ sleeve. The receiver groove distorts the gasket to prevent any straight path for combustion gases to escape.
At the level you are at, I wouldn’t do it any other way.
Re: "O" ringing Hemi Head and Block [Re: 590 Challenger] #2481001
04/11/18 11:32 AM
04/11/18 11:32 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
In the old days there was a standard o-ring size/location on top of the sleeve and then a matching receiver groove in the head. You are wise to try to follow a standard path. But nowadays it seems everybody wants to be different and it makes things a lot harder. I had a new billet Pro Mod Hemi in the other day that had the old, old way of oringing the heads. It drives you crazy. Try to find out the closet thing to "standard" and go with it.
2011 Drag Pak Challenger
Re: "O" ringing Hemi Head and Block [Re: 590 Challenger] #2481047
04/11/18 01:03 PM
04/11/18 01:03 PM
hemi-itis Offline
hemi-itis  Offline
Funny how LEAN really is MEAN!!,,,,,,,,,,NOT!!!!
Re: "O" ringing Hemi Head and Block [Re: TRENDZ] #2481150
04/11/18 04:07 PM
04/11/18 04:07 PM
ca
brownout Offline
brownout  Offline
ca
That is your answer. Good copper gasket. I had my Indy block done and receiver groove in the heads. .043 wire. I will see if I can get specs as to depth of the oring groove and receiver groove for you.
Cody
Re: "O" ringing Hemi Head and Block [Re: brownout] #2481226
04/11/18 07:42 PM
04/11/18 07:42 PM
Parts unknown
Parts unknown
Cody
Thanks, a outside diameter would be great too
Re: "O" ringing Hemi Head and Block [Re: 590 Challenger] #2481239
04/11/18 08:15 PM
04/11/18 08:15 PM
Washington
madscientist Offline
Washington
I always ran the wire in the heads and left the groove in the block as the receiver groove.
The reason is you can get the wire very close to the edge of the chamber (especially with some wedge heads) and the wire helps support the groove. If there is no wire in the groove and it gets a little hot in that area it can fold up quicker without the wire in it.
I always grooved the block, put some rings in the block that weren't butted up and then put some bluing on the heads. I'd then bolt the head down and it would leave an impression where the groove should be.
Then up in the manual mill, indicate everything in and center the tool holder that was made to be used in the mill and cut the grooves.
Re: "O" ringing Hemi Head and Block [Re: 590 Challenger] #2481264
04/11/18 08:51 PM
04/11/18 08:51 PM
Cab_Burge Online work
Cab_Burge  Online Work
SCE gaskets sells some copper head gaskets with the stainless steel O rings already embedded in them work scope
They work well up
Re: "O" ringing Hemi Head and Block [Re: Cab_Burge] #2481286
04/11/18 09:41 PM
04/11/18 09:41 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
They work well up
If they hold up , sounds like a better solution to me. up
Re: "O" ringing Hemi Head and Block [Re: 590 Challenger] #2481620
04/12/18 01:40 PM
04/12/18 01:40 PM
Parts unknown
Parts unknown
I found someone to explain it to me,
He said to use .041 wire and cut groove .039 wide, let the wire come out .010 to .012 out of the head. The receiver groove in the block needs to be .051 wide and .020 deep.
He says the O ring always goes in the head and not the block, reason being is the the sleeve is hard and won’t distort and neither will the head with the ring in it, if you do it the other way what happens is the receiver groove in the aluminum of the head is soft, when the gasket gets stuffed into the edges of the receiver groove takes all the pressure and start to distort causing problems that can’t happen if the groove is in the block
Re: "O" ringing Hemi Head and Block [Re: 590 Challenger] #2481654
04/12/18 02:41 PM
04/12/18 02:41 PM
Washington
Washington
That's correct. I didn't know you wanted wire diameter etc. That guy gave you the straight poop.
Re: "O" ringing Hemi Head and Block [Re: 590 Challenger] #2481706
04/12/18 04:19 PM
04/12/18 04:19 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
It's going to fly at 45 PSI
Re: "O" ringing Hemi Head and Block [Re: FastmOp] #2481730
04/12/18 05:08 PM
04/12/18 05:08 PM
Parts unknown
Parts unknown
I like the way you think, lol. It will be a cooler charge to spinning the blower slower, How much boost are you hit your's with?
