Page 1 of 3 1 2 3
Gen III AL block, big power gain! Ma Mopar paying racers! #2480947
04/11/18 09:43 AM
04/11/18 09:43 AM
gregsdart Offline OP
I stopped buy Chuck Lofgrens shop yesterday for help with a trans. We got to talking about his DragPak FS/D Challenger. His car is spotless, both underneath and everywhere else. Just like his one owner 1970 Sixpak Cuda (!)
Chuck put the newly allowed aluminum 6.1 block in the car, and picked up 35 hp.
The old block only made 665 hp, the AL motor made 700! Pretty good gain IMHO.
Now the problem is it carries the front wheels out to past the 60 clocks! His best et to date is 9.55, and he wound up with a class trophy in F Super Stock, entering in SS because he didn't have enough points to run in FS at the Nationals.
Ma Mopar also wants all the DragPack cars at an upcoming event at Route 66 in Joliet, and is paying handsomely to get them there! Nice!
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2480961
04/11/18 10:22 AM
04/11/18 10:22 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Never mind
Boffin Emeritus
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481030
04/11/18 12:36 PM
04/11/18 12:36 PM
The block only
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481034
04/11/18 12:40 PM
04/11/18 12:40 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
popcorn
Kevin
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: Twostick] #2481055
04/11/18 01:24 PM
04/11/18 01:24 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Must be fake news. No way an aluminum block can make as much, let alone more power than its iron equivalent stirthepot
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481062
04/11/18 01:33 PM
04/11/18 01:33 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Al, you certainly have a lot more experience than I do in this area but I can see how a very well engineered aluminum block with thick strong sleeves could provide a better ring seal that a iron block that might be more flexible. Of course ring seal equals power.
If this is the block I am thinking of it has more strengthening ribs in the valley that I have ever seen in a block.
That being said there could be lots of other factors with a completely different engine that could have accounted for the horsepower.
Bill
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481071
04/11/18 01:43 PM
04/11/18 01:43 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The NEW aluminum MP block certainly seems to be contributing to a lot of performance gains. Including the first ever 7 second Factory Shootout Pass
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481082
04/11/18 01:57 PM
04/11/18 01:57 PM
Guitar Jones Offline
So is it the block or not?
Confused in Peoria
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481088
04/11/18 02:03 PM
04/11/18 02:03 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Maybe I did not use enough sarcasm or the right emoji boogie
Greg stated that the ONLY change was the block. Also what was credited for the first 7 second pass, the new aluminum block.
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481133
04/11/18 03:17 PM
04/11/18 03:17 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Is there ventilation between the main webbing above the main bearing and below the bores in those iron or aluminum blocks?
I noticed the LS guys are running ventilation in there to get some breathing back and forth and keep from having high and low pressure areas in the crank case so I went to look at my blocks and noticed on the BGE block there is vents there already between the center bores at least but they are not on the 5.7 blocks. I don't have a 6.1 block here now and have never got to look that close at any of the non-production blocks. There could be some other changes unrelated to the material that are helping HP production also.
There are lots more things related to material that can alter HP between the blocks than just ring seal. Temp should be more uniform allowing more compression(don't sound like they took advantage of that here). Vibrations should be dampened better allowing more stable valve train dynamics.
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: Al_Alguire] #2481137
04/11/18 03:21 PM
04/11/18 03:21 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I considered scraping my Keith Black aluminum block because I read on the Internet that I would lose horsepower by using it. I started buying 40 year old stock cast blocks again.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: pittsburghracer] #2481140
04/11/18 03:32 PM
04/11/18 03:32 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Ill pay you 50Cents per pound, I will cover shipping and throw in a case of beer just so you don't have to use that HP sucking device. If you are very prompt about shipping and the block is still useable in my 9 passenger wagon I will throw in a 76 440 6pk max wegee hemi block from a motor home.
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481282
04/11/18 09:35 PM
04/11/18 09:35 PM
Some good points were made on the gains being possibly more than ring seal, although I heard the stock 6.1 blocks didn't like much overbore?
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481560
04/12/18 11:58 AM
04/12/18 11:58 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Never mind
Boffin Emeritus
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481581
04/12/18 12:18 PM
04/12/18 12:18 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
stability of a casting under load is the reason - you would be suprised how much a casting can move under power - roush actually has a dyno jig to do the measuring and does quite bit of testing for the big three. Sooner or later there will be an aftermarket block for the Genn III
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481586
04/12/18 12:23 PM
04/12/18 12:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Wasn't that part of what the "new" KB was going to be working on?
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481705
04/12/18 04:16 PM
04/12/18 04:16 PM
I tried what I saw in a video, putting a snap gauge in a vertical cylinder bore of a stock block, so the tension of the gauge was all it was held in there by. I could squeeze the block and make it drop out. If I can do that, you have to wonder how much the blocks twist, flex and distort under severe loads.
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481733
04/12/18 05:13 PM
04/12/18 05:13 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Never mind
Boffin Emeritus
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481746
04/12/18 05:31 PM
04/12/18 05:31 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
"An aluminum block as stiff as cast iron is impossible:"
True if cast identically - not true if designed differently
You need to think in three dimensions i.e. a trussed design
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481756
04/12/18 05:51 PM
04/12/18 05:51 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Hey, that's great for the guys who want to run a FS deal. What's Tony doing for those who don't have the budget to do that or just want to run a traditional S/SS class car?
Page 1 of 3 1 2 3
