how do you test the #2480684
04/10/18 07:49 PM
04/10/18 07:49 PM
GoDartGo Offline OP
GoDartGo  Offline OP
How do I test the control box? I got it new 7 years ago and never had any issues with it. It's the the orange control box and I'm not getting any spark. The coil is fairly new.
Re: how do you test the [Re: GoDartGo] #2480717
04/10/18 08:52 PM
04/10/18 08:52 PM
You pretty much have to test/elim all but the box & I think O'reillys can test it. it has ran in the past with how you have it wired correct? 4 pin ECU/2 terminal ballast & it wont start so you subbed in the orange box to no avail? pull the yellow wire off of the "ign" terminal on the starter relay to disable the starter & with your VOM see if the coil positive primary terminal & the main feed wire at the ECU are hot (it is the "point" of the pentastar), might be blue/yellow or red. ohm the dist pickup. check the reluctor gap (should be "close" but not touching) & the spec is .008" with a brass feeler gauge. confirm the box is grounded (it usually is but I would check). this'll get us started.
Re: how do you test the [Re: GoDartGo] #2480760
04/10/18 09:56 PM
04/10/18 09:56 PM
Europe
rory73 Offline
rory73  Offline
Europe
Re: how do you test the [Re: rory73] #2480768
04/10/18 10:05 PM
04/10/18 10:05 PM
^^^ Good info, thank you!
Re: how do you test the [Re: RapidRobert] #2480772
04/10/18 10:13 PM
04/10/18 10:13 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Yup, I copied it thanx. up
I have mechanical Aptitude.
I can screw up anything.
Re: how do you test the [Re: GoDartGo] #2480916
04/11/18 03:47 AM
04/11/18 03:47 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Who here has even seen brass feeler gauges? Not I....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: how do you test the [Re: GoDartGo] #2480922
04/11/18 05:08 AM
04/11/18 05:08 AM
CA
crackedback Offline
crackedback  Offline
CA
I have 3 sets of brass feelers for doing this ignition gap function. Not that unusual.
https://www.ebay.com/itm/Performance-Tool-W80526-6-Blade-Non-magnetic-Brass-Feeler-Gauge/401333029502?epid=1539519277&hash=item5d71500a7e:g:8SIAAOSw8lpZJJJF
Re: how do you test the [Re: GoDartGo] #2480970
04/11/18 10:42 AM
04/11/18 10:42 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I have a set!
Re: how do you test the [Re: Stanton] #2480975
04/11/18 10:50 AM
04/11/18 10:50 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have a set!
I have them too.
Re: how do you test the [Re: justinp61] #2480983
04/11/18 11:06 AM
04/11/18 11:06 AM
ND
dodgedon Offline
dodgedon  Offline
ND
Every set I have has a few brass sizes in the mix.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: how do you test the [Re: dodgedon] #2481205
04/11/18 06:26 PM
04/11/18 06:26 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Same here. I have a set with several brass sizes int he mix.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: how do you test the [Re: GoDartGo] #2481336
04/11/18 11:20 PM
04/11/18 11:20 PM
GoDartGo Offline OP
GoDartGo  Offline OP
WOW!! That's good stuff there. Thank you! I'm going thru the process of elimination. So far nothing.
Re: how do you test the [Re: GoDartGo] #2481339
04/11/18 11:25 PM
04/11/18 11:25 PM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
Me too, have several sets, from when I was young.
A True Hybrid: Burns Gas AND Rubber!
