OK, we manufacture the distributors. We ended up selling them to Summit and Jegs due to them selling thousands. Wires are still all ours. We will not sell out on those. Mancini and R/T Garage are our direct distributors for wire sets and most distributors. The RTR's didn't move that well, so the big guys took over those. I ran a RTR for two years...perfect.. Mike Ross has them on some of his Hemi Cudas.. Perfect.. The biggest culprits of issues are dirty bulkhead connectors, using the old points style voltage regulators, a weak alternator, and jumping the ballast incorrectly, or still trying to use the ballast resistor, or using the wrong coil. If a customer is already having ignition issues, most times the electronic issues will follow to whatever you replace it with. If everything is clean, grounds are perfect, great supply voltage, these pieces will work perfectly.. These need every bit of 12.9 and over volts. You never called back, so I figured you fixed it. I don't know unless you call me back.. I needed pics to maybe see any obvious issues.
