FIBERGLASS HOOD W/HINGES #2480821
04/10/18 11:33 PM
04/10/18 11:33 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
I have a FB hood for my '65 dart. Its a pin on style Any way of hinging it at the back and then use a pole to keep it open. Any way of using the stock hinges and the factory torsion bar set up?
Re: FIBERGLASS HOOD W/HINGES [Re: A/MP] #2480849
04/11/18 12:22 AM
04/11/18 12:22 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
You probably could glass something to the bottom of your fiberglass hood to bolt your hinges to. I was going to use a piece of wood fiberglassed on with J bolt's going through it and have nuts to hold the hinges to the hood . Lift off hoods are not designed for any spring pressure , Loose the torsion bars and you'll be OK
Re: FIBERGLASS HOOD W/HINGES [Re: A/MP] #2480867
04/11/18 12:52 AM
04/11/18 12:52 AM
west palm beach, florida
modelmakerinc Offline
On my Fury I hinged the fiberglass hood, you are in luck because you have hinges that do not have tension like most later year hoods do. get rid of the hood torsion bars and make a pair of gas struts (hatch back) lift struts work.
Sorry no pics on this computer to share.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: FIBERGLASS HOOD W/HINGES [Re: modelmakerinc] #2480871
04/11/18 01:04 AM
04/11/18 01:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I made mine so I could hinge it.. I like a
single stainless tube for a strut rod so
I did it that way... this was a pin on hood
wave
Re: FIBERGLASS HOOD W/HINGES [Re: A/MP] #2480874
04/11/18 01:13 AM
04/11/18 01:13 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I bonded my fiberglass aar cuda hood to a steel hood inner structure with 3m adhesive. You can remove a lot of the inner framing also, but it really doesn't weigh much. Will use hood pins but will also have a safety latch just in case I forget the pins.
If you want to use just a hinge... using a 2 part adhesive, you can bond metal to the glass and will be very strong.
You just use the outer section of the frame or as much as you want... will fit like an oem hood.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: FIBERGLASS HOOD W/HINGES [Re: MR_P_BODY] #2480875
04/11/18 01:13 AM
04/11/18 01:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
This is what it looks like now.. I added 2
button locks to hold it closed
wave
Re: FIBERGLASS HOOD W/HINGES [Re: A/MP] #2480899
04/11/18 02:09 AM
04/11/18 02:09 AM
I bonded on some aluminum 2.0 x2.0 inch wide and tall T shape on the bottom of my fibreglas race lift off hood on my old pump gas Duster and use bolts to bolt them to the stock Duster hood hinges so I could use a sawed off broom stick to hold the hood opened devil
That worked well up
Re: FIBERGLASS HOOD W/HINGES [Re: A/MP] #2481361
04/12/18 12:06 AM
04/12/18 12:06 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
I had given thought to using factory underhood frame. Getting hard to find a hood that isn't twisted or so far away that the freight costs more than the hood. I like the ability to have the factory hinge. At a quick glance the factory hinge would make the hood look stock. Structurally speaking, aluminum tubing stronger than solid wood of the same dimensions? Since aluminum oxidizes quickly, do you scuff then clean and epoxy for the best results?
Re: FIBERGLASS HOOD W/HINGES [Re: A/MP] #2481422
04/12/18 01:43 AM
04/12/18 01:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
On my hood I used 2 3/8 bolts on each side.. I
milled a slot in the alum so the nuts could
slide some.. I painted all that stuff then I
glassed it to the hood.. I did it so the glass
and alum came out level om the hood.. when it
all dried I bolted the hood on but left it
just so it would move some.. once lined up just
tightened it tight.. I had to add a washer on
one side to line up the hood
wave
