Paint under the Vinyl Roof? #2480565
04/10/18 04:36 PM
04/10/18 04:36 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
A friend is having his original vinyl roof 69 Dart repainted. He sent me some progress pictures that he took at the paint shop yesterday. When I saw them, I noticed that the painter had left the roof area just in primer figuring that the area will not need painting because it will be later covered with a vinyl top.
I called him today and told him that it would be a mistake not putting color on the roof.
Any opinions on this issue?
Re: Paint under the Vinyl Roof? [Re: rarefish] #2480579
04/10/18 04:52 PM
04/10/18 04:52 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
From the factory,if a car is optioned with a vinyl top as per broadcast sheet,the roof does NOT get painted.
One of the ways the factory kept costs down.
As we already know,many a Mopar had suffered roof rot from that executive decision.
You can either paint it or not but the surface still has to be scuffed for the glue required for the top.
My car had a dealer installed top over factory paint.
During my restoration,I chose to use a high quality epoxy primer on the roof and not paint the roof when I replaced my top.
Hope this helps.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Paint under the Vinyl Roof? [Re: rarefish] #2480589
04/10/18 05:06 PM
04/10/18 05:06 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I've never removed a top and saw just primer... not fully painted to be nice like the rest of the car, but definitely has over spray. Some heavier than others like the interior area.
I always just paint them like the rest of the car when restoring one. Maybe not multiple coats, but til covered then cleared with the rest of the car.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Paint under the Vinyl Roof? [Re: Silver70] #2480625
04/10/18 06:15 PM
04/10/18 06:15 PM
New Mexico
JMCFAN Online content
JMCFAN  Online Content
New Mexico
Both of mine the roof was painted...not cleared....
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Paint under the Vinyl Roof? [Re: Silver70] #2480627
04/10/18 06:16 PM
04/10/18 06:16 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
Tell them to paint the roof, I just primed the roof of my Charger and I got rust bubbles unded the vynal top. I will paint the roof of every vynal top car I ever do from here on out. I don't care about how they came from the factory. I also have another 73 Charger that I got from California, and the roof was wasted under the vynal top. I had to change the roof skin,the car had no rust anywhere else.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Paint under the Vinyl Roof? [Re: chargervert] #2480632
04/10/18 06:24 PM
04/10/18 06:24 PM
michigan
440whiteboy Offline
440whiteboy  Offline
michigan
I agree - primer is Not a Sealer - water will bleed thru.
At the least a quality sealer should be used. Does not take much more paint or time to spray the top with base color, then to top coat with clear.
If you don't use clear, the paint could pull/separate from the primer.
They only see Stars...
when hit by a Mopar!
Re: Paint under the Vinyl Roof? [Re: 68Cbarge] #2480637
04/10/18 06:35 PM
04/10/18 06:35 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Hope this helps.
I always paint the roof fully and with the same coverage/technique used on the body when doing a vinyl top vehicle, it's not worth the risk to have it develop rust years down the road by being cheap, and no need to "scuff" the paint either as long as no polish/wax has been applied to it, otherwise I'd just lacquer thin the area where the vinyl top is going to be applied
Also not a good idea to drill for molding top clips/studs/etc after paint, that should have been done long before paint... and don't use any silicone sealer products on clips/studs/moldings/etc when installing a top, it will only promote rust by retaining moisture/water, use body caulk or urethane type sealer for holes/screws/clips/etc
Re: Paint under the Vinyl Roof? [Re: 440whiteboy] #2480645
04/10/18 06:44 PM
04/10/18 06:44 PM
New Mexico
New Mexico
I would think the clear could cause adhesion problems... dont know.. but Charger resto is 20 years old... still looks great...
Re: Paint under the Vinyl Roof? [Re: JMCFAN] #2480651
04/10/18 06:55 PM
04/10/18 06:55 PM
chargervert Offline
chargervert  Offline
If you scuff the roof with a Scotch bright pad the glue will adhere fine.
Re: Paint under the Vinyl Roof? [Re: rarefish] #2480653
04/10/18 06:57 PM
04/10/18 06:57 PM
KY
65pacecar Offline
65pacecar  Offline
KY
When we pulled the original factory vinyl top off our 69 RR the top was fully painted (A14) car. When we repainted the car we fully prepped and painted the top the same as the rest of the car and put the vinyl top back on. Excellent rust protection and worth the extra money for paint.
Re: Paint under the Vinyl Roof? [Re: rarefish] #2480659
04/10/18 07:07 PM
04/10/18 07:07 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Thanks everyone here for the replies. I getting the answers that I pretty much expected. "Paint it"....
We all know primer alone does not protect against rust and the vinyl top material is not water proof.
Re: Paint under the Vinyl Roof? [Re: JMCFAN] #2480707
04/10/18 08:39 PM
04/10/18 08:39 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've painted vehicles in single stage as well as BC/CC, painted the roofs just like the body, never scuffed/sanded the gloss finish of either paint prior to installing a vinyl top, I have 3 cars that wear vinyl top, one in single stage the others in BC/CC, the oldest top is about 30 yrs old, the newest top is about 14 yrs old, no lifting, no bubbles, zero issues, it's all in a quality application and products
Re: Paint under the Vinyl Roof? [Re: DAYCLONA] #2480786
04/10/18 10:31 PM
04/10/18 10:31 PM
New Mexico
New Mexico
AGREE I tried to install my first one on the 68... what a disaster... I will leave that to the pros....
Re: Paint under the Vinyl Roof? [Re: rarefish] #2480810
04/10/18 11:07 PM
04/10/18 11:07 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
The ones like legendary sell are very easy to install. They don't have much stress and you can basically install it like a vinyl graphic. The cheaper ones that stretch, I won't even try anymore. If you try to do it like the legendary tops, they look terrible! It maybe a make thing too. I only use legendary tops, but was asked to do one on a gm and used their top, no idea on bramd, that's the one I couldn't get right.
Re: Paint under the Vinyl Roof? [Re: Silver70] #2480828
04/10/18 11:40 PM
04/10/18 11:40 PM
New Mexico
New Mexico
Mine was Legendary...but it was Dec... bad idea...
Re: Paint under the Vinyl Roof? [Re: rarefish] #2480878
04/11/18 01:19 AM
04/11/18 01:19 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I made that mistake once also and it shrunk after trimming... but did it with the glass in. Otherwise it would have had the revel trim clip screws through it to help out that part.
Re: Paint under the Vinyl Roof? [Re: JMCFAN] #2480886
04/11/18 01:28 AM
04/11/18 01:28 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Had that experience too - bad idea.
Took it to an expert that had a UV lamp set up
Re: Paint under the Vinyl Roof? [Re: rarefish] #2481091
04/11/18 02:11 PM
04/11/18 02:11 PM
pa.
dan9 Offline
dan9  Offline
pa.
I painted mine with single stage prior to the vinyl top.
