67 440 HP Fan Blade #2480231
04/09/18 10:52 PM
04/09/18 10:52 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
My 67 GTX has an aftermarket fan and fan clutch that were on the motor when I got the car. Would the correct fan for a 67 440 HP motor be a fixed spacer-style or a clutch fan? I'd like to put an original fan (and clutch or spacer if applicable) on it. Also, what would be the correct part number for the fan blade? Thanks in advance.
Re: 67 440 HP Fan Blade [Re: 440mopar] #2480321
04/10/18 01:42 AM
04/10/18 01:42 AM
it wouldn't surprise me to find out that those cars came with both, depending on what the factory had on the shelf the day the motor was assembled shruggy
Re: 67 440 HP Fan Blade [Re: 440mopar] #2480437
04/10/18 12:33 PM
04/10/18 12:33 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Shop manual has Thermal drive listed for A/C equipped, 1.24" spacer for all others. 3 different fans used depending on the trans, A/C, trailer package etc.
Get those listed and someone here or in the restoration forum can help you out.
