Lead on a 68 Satellite #2478913
04/07/18 04:52 PM
04/07/18 04:52 PM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
What all b-body parts interchange? It is rumored to be burnt from a gas tank fire from the rear bumper to the firewall, so it needs lots of parts.
Update it for sure needs all the glass and the interior, since it needs interior I presume it needs wiring too. Taillights for sure too.
eBay-cdwmotorsports
Re: Lead on a 68 Satellite [Re: cdwmotorsports] #2479073
04/07/18 09:57 PM
04/07/18 09:57 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If it got hot enough, I'd be worried about the exterior sheet metal. As for trim, '68 Satellites are fairly common, pretty well covered in the resto aftermarket, and a fair amount of things sure look like they would interchange '68-'70. Differences in seat back release on '70, door lock knob location '68, dash pads, other details. A lot depends on how '68-accurate you want.
Re: Lead on a 68 Satellite [Re: cdwmotorsports] #2479375
04/08/18 01:15 PM
04/08/18 01:15 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What makes it so special that you would even both with something so extensively damaged ?? The time and money to restore it would exceed the final value by so much its ridiculous.
Re: Lead on a 68 Satellite [Re: Stanton] #2479501
04/08/18 04:39 PM
04/08/18 04:39 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
68 through 70 B body... very similar.
The glass would be Plymouth B body or Dodge Coronette.
Also depends on coupe or sedan.
Some parts will be Plymouth specific and some will exclude Charger.
I too would be concerned with the metal fatigue cause by heat.
Also agree it would cost way more to fix then it will ever be worth.
I have mechanical Aptitude.
I can screw up anything.
Re: Lead on a 68 Satellite [Re: cdwmotorsports] #2480142
04/09/18 07:29 PM
04/09/18 07:29 PM
Martinsville, IN
Martinsville, IN
I haven't even seen pics of it, so I am going off a verbal description. None of this even matters as he has chosen not to sell it.
Thanks for the responses.
eBay-cdwmotorsports
Re: Lead on a 68 Satellite [Re: cdwmotorsports] #2480532
04/10/18 03:35 PM
04/10/18 03:35 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I don't think metal fatigue is a problem with a fire. The majority of strength in body panels is due to cold working them by stamping. Heat anneals the cold working stresses and the panel ends up being like 'butta'.
