Dana 60 shock mounting plate #2480040
04/09/18 03:35 PM
04/09/18 03:35 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Are the Dana 60 shock mounting plates identical whether it is for a b body or e body? Any difference in year models? Thanks
Re: Dana 60 shock mounting plate [Re: gregok] #2480062
04/09/18 04:18 PM
04/09/18 04:18 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
In 1970 they are the same.Usualy called the "long" style or TA version.I am not sure if they used them in 71 or switched back to the short style.
Re: Dana 60 shock mounting plate [Re: 44D6PAKCUDA] #2480115
04/09/18 06:04 PM
04/09/18 06:04 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Visually, can a person tell the difference? I need to buy a set and saw some on the bay.
Re: Dana 60 shock mounting plate [Re: gregok] #2480151
04/09/18 07:46 PM
04/09/18 07:46 PM
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
Yes,the lower shock stud/mount hangs down lower (approx. 1") for longer shock travel I would guess than the standard short plate.
