69 440 6-bbl #2479678
04/08/18 11:08 PM
04/08/18 11:08 PM
Illinois
sixbbl 69 Offline OP
Illinois
what is the differance in auto center carb and 4sp center carb?
Re: 69 440 6-bbl [Re: sixbbl 69] #2479751
04/09/18 12:55 AM
04/09/18 12:55 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
idle circut is set to run richer to not stall at idle in the auto when in gear.
Re: 69 440 6-bbl [Re: sixbbl 69] #2479829
04/09/18 08:42 AM
04/09/18 08:42 AM
Illinois
Illinois
i am going to run a set of 70 carbs on my 69 4sp car [4383,4382 and 4376] while i rebuild my 69 carbs and didn't know how it would run with center carb being a auto.i guess i won't be able to tell much differance in the way it runs. thanks for reply
Re: 69 440 6-bbl [Re: sixbbl 69] #2479849
04/09/18 09:58 AM
04/09/18 09:58 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
They both use the same 6020 metering block,4 spd main jetting is one size richer than auto.
Re: 69 440 6-bbl [Re: sixbbl 69] #2480045
04/09/18 03:46 PM
04/09/18 03:46 PM
They all will work fine for you up scope
I've had a bunch of different six packs on a lot of different motors, stock to all out fast race motors with a lot of different List number carbs. with no problems other than getting the outboard carbs to open the way I wanted them to wrench Lots of fun dialing in carbs. grin
Re: 69 440 6-bbl [Re: sixbbl 69] #2480051
04/09/18 03:58 PM
04/09/18 03:58 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Curb idle speeds and fast idle speeds are set differently also. They have all the different list numbers of carbs so they can pick the right one off the shelf for the engine/Trans combination.
Re: 69 440 6-bbl [Re: Cab_Burge] #2480284
04/10/18 12:06 AM
04/10/18 12:06 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Originally Posted By Cab_Burge
List number crabs. with no problems
Usually you can get a cream for that grin drumhit
Re: 69 440 6-bbl [Re: Morty426] #2480308
04/10/18 01:17 AM
04/10/18 01:17 AM
When I lived close to the Mexican border as a kid I heard about them animals, but I never had to deal with them though whistling
Re: 69 440 6-bbl [Re: Cab_Burge] #2480355
04/10/18 06:56 AM
04/10/18 06:56 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Good to know grin up
