how do you check a clutch fan #2479585
04/08/18 07:42 PM
04/08/18 07:42 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
Have a 2004 1500 with a 4.7 it trys to over heat. rad looks good. belt are good changed stat. new antfreeze any ideas??? Also how do you check a clutch fan?? Thanks
Re: how do you check a clutch fan [Re: dragon] #2480016
04/09/18 03:18 PM
04/09/18 03:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You can't test a fan clutch; if in doubt, the factory says to replace with a "known good unit".
Re: how do you check a clutch fan [Re: dragon] #2480074
04/09/18 04:47 PM
04/09/18 04:47 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Go back to your rad and pressure wash the living daylights out of it. You should have clear water flowing out of every inch of it. Spend at least half an hour at it.
Over time, dust settles on the bottom row of fins and keeps getting worse.
Unhook the heater core and flush it out too.
Easy job on those, grille raises with the hood. Not like these new ones where they went away from that obviously great idea.
Only way I know to test for the clutch fan is to listen it to it. They roar when they are working, you can't miss it. Most vehicles do it cold when you first start out for a few seconds.
Mo' Farts
Moderated by "tbagger".
Re: how do you check a clutch fan [Re: dragon] #2480248
04/09/18 11:20 PM
04/09/18 11:20 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
You sure it overheats? Maybe sender?
I want my fair share
Re: how do you check a clutch fan [Re: dragon] #2480870
04/11/18 01:00 AM
04/11/18 01:00 AM
ohio
dragon Offline OP
dragon  Offline OP
ohio
Thanks I will go back and check the rad and take a temp gun and check the temp at rad and stat houseing it great to have a place to get a answers and ideas. Thanks
Re: how do you check a clutch fan [Re: dragon] #2480955
04/11/18 10:02 AM
04/11/18 10:02 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Back in 1995 the FSM for Rams has a test for the clutch fan that involves using a heat gun aimed at the fan clutch and listening for the change in sound when it thermally locks up and raises the rpm of the fan to engine speed.
Back about 1998 when I tried this test I realized I had a 12 volt powered adjustable Stroboscope with a digital rpm readout from mining work that I had bought to field check the rpm of pump pulleys and electric motors. I got it out and found that i could easily measure the rpm of the fan, and the boost in rpm when the Magnum 5.9 V8 fan clutch locks.
The cost of these has come down since the 1980s:
https://www.amazon.com/Landtek-Instrumen...rds=Strobescope
My fuzzy memory tells me the early 2000’s 4.7 V8 thermal clutch slips quite a bit more when unlocked because it has a lower viscosity silicone fluid as a EPA fuel economy improver. When Chrysler press release came out that year and touted that change I thought about buying one and attempting to use it on my 1995.
Re: how do you check a clutch fan [Re: dragon] #2485652
04/20/18 04:04 PM
04/20/18 04:04 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
"test" . . .see if there is play on the shaft . . . then feel if it is "free wheeling" (free wheeling) when cold . . . feel if it is "locked in" (not slipping) when hot . . . .
Re: how do you check a clutch fan [Re: a12rag] #2486166
04/21/18 07:31 PM
04/21/18 07:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Viscous fan clutches never really "lock up" in normal operation. Like a non-lockup torque converter, there is always some slippage.
Re: how do you check a clutch fan [Re: John_Kunkel] #2495370
05/13/18 01:30 AM
05/13/18 01:30 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
You could get the engine hot and place a fender cover over the grill and see if it stay's there. Alot of time you can just see the fan just spinning slowly and not drawing air across the radiator. Also if the engine is hot and you turn the engine off but the fan keeps spinning for a bit it's shot. Going the other way if the truck sound like it is "roaring" while driving in normal temp it maybe stuck on. Many customers think their transmission is slipping because they hear this load roar but the truck is just going down the road normally.
Re: how do you check a clutch fan [Re: dragon] #2495487
05/13/18 12:56 PM
05/13/18 12:56 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I have a piece of cardboard at work to slide in front of the radiator. A/c off, bring the rpms up and sit and wait. Temp gauge will usually creep toward 3/4 before you hear an audible difference. Temp reading on scanner will be 220-240 depending on model.
