Mopar Ductile Main Caps ? / for Cab_Burge #2478384
04/06/18 04:37 PM
04/06/18 04:37 PM
parma,ohio
66littlebigmopar Offline OP
parma,ohio
In a previous post you were talking about using the 440 Source aluminum caps but mentioned the iron ones as first choice. I bought a set many years ago at a swapmeet and never used them, yet. Just one question they are all the same, no thrust bearing register, did I screwed or is that the way they came?
Re: Mopar Ductile Main Caps ? / for Cab_Burge [Re: 66littlebigmopar] #2478391
04/06/18 04:57 PM
04/06/18 04:57 PM
Cab_Burge Online work
Cab_Burge  Online Work
It depends on which brand they are, more than likely yours are not the
Mopar brand. They came with the center cap machine up
Milidon, KB and a lot of others don't come with them shruggy
Do you have a good machine shop to do the work for you?
Hopefully so luck
Re: Mopar Ductile Main Caps ? / for Cab_Burge [Re: Cab_Burge] #2478422
04/06/18 05:58 PM
04/06/18 05:58 PM
parma,ohio
parma,ohio
[img]caps[/img] Thanks they were cheap so I took a chance. they were in a Mopar box but buying used don't mean nothing.
Re: Mopar Ductile Main Caps ? / for Cab_Burge [Re: 66littlebigmopar] #2478605
04/07/18 12:39 AM
04/07/18 12:39 AM
Mopar had many different vendors on many of the same part #s over the years that weren't exactly identical to each other shruggy
Maybe yours where from KB in the older Mopar boxes shruggy
I bought 5 or 6 sets of the Mopar brand starting in around 1999-2001, all of them had the thrust surface machined, the last set I bought in around 2009 was from Milidon and they weren't machined whiney shruggy
I'm using 440 Source brand aluminum main caps now, they fit well, according to the machine shop I use, and work well so far up
I shouldn't be afraid of using steel main caps, especially on a RB block, but I am shruggy
Re: Mopar Ductile Main Caps ? / for Cab_Burge [Re: Cab_Burge] #2478970
04/07/18 07:18 PM
04/07/18 07:18 PM
HR3128 Offline
HR3128  Offline
What are the concerns with steel main caps? I have a set I was planning on using on a RB project. Just rounding up parts now.
Re: Mopar Ductile Main Caps ? / for Cab_Burge [Re: HR3128] #2478998
04/07/18 08:23 PM
04/07/18 08:23 PM
My concerns on using steel main caps on a cast grey iron block is I'm worried about the steel caps causing the main webbing to break sooner than the stock cast iron caps will due to dissimilar metals harmonic factors twocents work Maybe one of the brighter guys on here that know a lot more than me on this will chime in for better information input luck
The after market aluminum and ductile iron caps don't have a history of doing that work
I've assembled several KB aluminum blocks, they came with steel main caps from KB so I know they will work fine on a aluminum block shruggy
Now the real question for you is "Are you feeling lucky" whistling grin
I'm not tsk
Re: Mopar Ductile Main Caps ? / for Cab_Burge [Re: 66littlebigmopar] #2479476
04/08/18 03:52 PM
04/08/18 03:52 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
In my opinion, if it's a 400 block I don't see the problem with billet steel caps, which is the route I took. I would not do that on a 440.
I think 1k to align hone, and align bore is a lot of coin to put a cast cap back in.
Re: Mopar Ductile Main Caps ? / for Cab_Burge [Re: 66littlebigmopar] #2479518
04/08/18 05:18 PM
04/08/18 05:18 PM
P
Porter67 Offline
Porter67  Offline
P
Of the two shops I use they pefer the caps that are uncut and cut the thrust area themselves as they feel its more accurate of a job.
But ive had mopar caps from the box, same PN with some cut, some were not.
