E-Body Rear End Swap #2479506
04/08/18 05:00 PM
04/08/18 05:00 PM
NY
K
Killerinc Offline OP
K
NY
Is there a shorter 8 3/4 rear end that will bolts in to an E-Body?
Or should i just get the Offset spring mounts and move the perch?
Wanting to get a larger tire in the rear.
thanks
Re: E-Body Rear End Swap [Re: Killerinc] #2479509
04/08/18 05:04 PM
04/08/18 05:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The E-body spring perch centers are 46", there is no housing with 46" centers that is narrower.
Re: E-Body Rear End Swap [Re: Killerinc] #2479514
04/08/18 05:15 PM
04/08/18 05:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
thanks
There's no bolt in E body axle swap per say, it depends on where you want your wheel/rim offset/back spacing, if your looking for a more positive or neutral offset on a set of wider rims you could move the perches on the E body axle inboard along with a spring relocation set up...
If your looking for more negative wheel offset on wider rims you can use the spring inboard relocation set up that allows you to bolt in the narrower stock 68-70 B body axle
You need to determine your rim offset choice first
Re: E-Body Rear End Swap [Re: Killerinc] #2479528
04/08/18 05:35 PM
04/08/18 05:35 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
You can use a 1968-70 B-body rear with Doctor Diff's 1" offset spring kit.
http://www.doctordiff.com/e-body-offset-spring-hanger-shackle-kit.html
Re: E-Body Rear End Swap [Re: Alaskan_TA] #2479677
04/08/18 11:04 PM
04/08/18 11:04 PM
NY
K
K
NY
Awesome thanks to you all
Re: E-Body Rear End Swap [Re: DAYCLONA] #2479681
04/08/18 11:09 PM
04/08/18 11:09 PM
NY
K
K
NY
Gotcha, didn't give that any thought yet, but if i do the B body rear and 1" offset spring kit will i be shooting myself in the foot for harder to get wheels?
thanks
Re: E-Body Rear End Swap [Re: Killerinc] #2479687
04/08/18 11:13 PM
04/08/18 11:13 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
When I did mine, I had custom width 10" wheels with wide meats & they fit perfect.
They have sold since though & I do not have a record of the back space.
There are companies out there that make wheels to order.
Re: E-Body Rear End Swap [Re: Killerinc] #2479708
04/08/18 11:50 PM
04/08/18 11:50 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
I had the perches cut off a B-body rear and new ones welded on at the 46 inch spec. If you are running a factory sway bar that is the way to go. Using offset shackles to move the springs will throw off your end link geometry.
No sway bar or aftermarket sway bar then the shackles are the way to go.
I'd suggest really planning out your wheel tire combo before swapping rears. I think someone makes a tool you can bolt to the axle and adjust to simulate different tire and rim combinations and then rotate it to see if it hits anything. Measure twice, swap parts once... or something like that
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: E-Body Rear End Swap [Re: Killerinc] #2479765
04/09/18 01:32 AM
04/09/18 01:32 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
For reference, if you install my 1" offset E-body hanger/shackle kit, a '65-'67 B-body rear, drum brakes and 10" wide wheels with 5" of backspacing fit nicely.
A '68-'70 B-body rear, typical disc brakes and 10" wide wheels with 5.5" of backspacing will also fit.
Re: E-Body Rear End Swap [Re: Killerinc] #2479979
04/09/18 02:19 PM
04/09/18 02:19 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
I put a b unit into my 70 e. Cut off the perches and placed them where they needed to be. You gain 3/4" per side clearance between the sidewall of the tire and the outer lip on the quarter. Tons of clearance for what I had on the tire/wheel combo of 15x8.5 torq thrusts and 265/50-15 comp t/a's.
Carl Kessel
Re: E-Body Rear End Swap [Re: Killerinc] #2480413
04/10/18 11:55 AM
04/10/18 11:55 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
I put a rear from 66 b body in our challenger. Bought the offset hangers from doc diff..all bolted right up. Fit a 28x12 m/t tire. On a 15x10 with 5 inch back spacing. No rubbing or cutting anything. Even wheel well molding
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: E-Body Rear End Swap [Re: DoctorDiff] #2480524
04/10/18 03:10 PM
04/10/18 03:10 PM
NY
K
K
NY
What about the previous comment
"Using offset shackles to move the springs will throw off your end link geometry."
Re: E-Body Rear End Swap [Re: Killerinc] #2480552
04/10/18 04:22 PM
04/10/18 04:22 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I am using a b-body dana with DrDiff offset hangers with a Hotchkis swaybar. Hotchkis does offer a bolt kit for clearance if needed for offset leaf spring users. I didn't need it.
Re: E-Body Rear End Swap [Re: Killerinc] #2480802
04/10/18 10:58 PM
04/10/18 10:58 PM
Columbus, GA
Columbus, GA
If I recall hotchkis bars ride under the axle unlike the factory or Firm Feel bars. If you go the offset hanger route substituting a rear sway bar from a B-body to match the width to the new spring location MAY work.
Re: E-Body Rear End Swap [Re: Michael Ecks] #2481129
04/11/18 03:08 PM
04/11/18 03:08 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
I'm using a 1967 B body rear under a 1971 R/T Challenger with Dr. Diff's offset spring hanger kit.
Everything fit perfectly and I'm using 15x10 wheels.
I put the factory sway bar in a big vise and bent each end in slightly, after a few attempts it fit perfectly.
Re: E-Body Rear End Swap [Re: Killerinc] #2484779
04/18/18 08:06 PM
04/18/18 08:06 PM
Round Rock, Tx
PlumCrazyChris Offline
Round Rock, Tx
The 65-69 C body 8 3/4s are a bolt in, you just have to shim the perches 3 degrees. The C bodies are 5 degrees I think, but the dimensions are exact for the perches 46" and the flange to flange is 1/8" wider on each side.
I put one in my 70 Challenger, it fits perfect.
VP of Mopar Muscle Cars of Austin
70 Challenger
www.mopar.org
Re: E-Body Rear End Swap [Re: KillerBee] #2486246
04/22/18 12:08 AM
04/22/18 12:08 AM
NY
K
K
NY
Very interesting, thanks
Curious though, if i was to get a 67 B body Sway bar would that be a direct fit?
How does she ride with those Mods?
Re: E-Body Rear End Swap [Re: Killerinc] #2486288
04/22/18 02:14 AM
04/22/18 02:14 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
They didn’t have a factory 67 B-body rear sway bar.
The old Addco rear sway bars are the same for A,B,E bodies they have a more universal attachment.
I believe hotchkis offers end links or bracket for Springs that are moved in
Re: E-Body Rear End Swap [Re: Killerinc] #2486351
04/22/18 12:10 PM
04/22/18 12:10 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
You actually don't need a different housing for additional tire clearance. Where the axle ends are is not the limiting factor as the first interference point is the leaf spring. Moving the springs in an inch removes the interference.
If you move the springs in then you can either A)bolt in a B body rear or B) keep your E body housing and weld on new spring mounts to realign with the the new spring location. Bolting in a a B housing simply eliminates any cutting or welding. It doesn't actually create any additional room over using the E body housing.
Of course, different offset rims are required if you use the E housing compared to the B housing if you are going to maximize the new space from moving the leafs.
If you do go the B body route, there is a difference in width between 67 and older and 68-70 that will impact you rim offset selection as well.
Re: E-Body Rear End Swap [Re: TC@HP2] #2486381
04/22/18 01:06 PM
04/22/18 01:06 PM
that'd be my choice.
