Favorite / best timing light ? #2479148
04/07/18 11:35 PM
04/07/18 11:35 PM
Washington
hemienvy Online content OP
hemienvy  Online Content OP
Washington
Not much luck with Search function....
What timing light do you recommend ? Maybe why ?
Re: Favorite / best timing light ? [Re: hemienvy] #2479181
04/08/18 12:57 AM
04/08/18 12:57 AM
Central US
grancuda Offline
grancuda  Offline
Central US
I still like my basic 20 year old timing light just for setting base timing.
I picked up a fancy new one a year ago from Summit for dialing in my mechanical advance & vacuum advance. Pretty cool you can dial in the initial timing & dial it back to the 0 on the balancer. Then you can dial it back & use the tac on the screen to do the mechanical & vacuum advance. It also does 2 stroke & its back-lit for nights.
https://www.summitracing.com/parts/ino-5568
A buddy of mine has the standard style with an actual dial to turn back the advance but he says it turns too easy & he has set it wrong because it slightly turned on him between adjustments.
1967 Barracuda Formula S 383
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
Re: Favorite / best timing light ? [Re: hemienvy] #2479183
04/08/18 12:57 AM
04/08/18 12:57 AM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
The old Sears chrome 2134 or 2138 light for on an MSD. MSD sold the same light years ago for use with their stuff. Or an old Snap-On adjustable knob type for everyday stuff. If they broke, I'd go looking for the same in mint condition. If buying new, a lot of guys like the battery powered lights.
Re: Favorite / best timing light ? [Re: hemienvy] #2479209
04/08/18 01:56 AM
04/08/18 01:56 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Re: Favorite / best timing light ? [Re: CMcAllister] #2479281
04/08/18 10:42 AM
04/08/18 10:42 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I still have one of those chrome sears lights barely used. It was my fathers. must be 30+ yrs old. My favorite light though would have to be the flaming river 1 wire 2 D cells.
Re: Favorite / best timing light ? [Re: hemienvy] #2479292
04/08/18 11:01 AM
04/08/18 11:01 AM
America
WedgeFED Offline
WedgeFED  Offline
America
Ferret makes the best timing lights, they make the msd ones...
Re: Favorite / best timing light ? [Re: WedgeFED] #2479431
04/08/18 02:41 PM
04/08/18 02:41 PM
Washington
Washington
Thanks much guys, GoManGo that is the thread I was thinking about.
I definitely need one that works with MSD.
Re: Favorite / best timing light ? [Re: hemienvy] #2479432
04/08/18 02:42 PM
04/08/18 02:42 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Anything that MSD sells for use with their stuff is fine, I'm sure. I still use the one I bought like 30+ years ago.
Re: Favorite / best timing light ? [Re: hemienvy] #2479440
04/08/18 02:48 PM
04/08/18 02:48 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Love my SnapOn one I bought back around 92.Never fails to work has RPM and feature to move timing forward and backwards.Pricey at the time but at work and home worked great.Rocky
Chrysler Firepower
Re: Favorite / best timing light ? [Re: hemienvy] #2479442
04/08/18 02:49 PM
04/08/18 02:49 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I have two old chrome Craftsman. One dial back, one not. Probably 25 years old. The self powered ones are cool for avoiding fans and moving parts.
Re: Favorite / best timing light ? [Re: Dave Hall] #2479553
04/08/18 06:30 PM
04/08/18 06:30 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
If you run an MSD ignition with a crank trigger you may find that you can't use an adjustable timing light. I have the Snap On adj light and a digital snap on and neither will work. I also tried the adj. chrome craftman and it won't work either. I ended up buying the battery powered Flaming River light,and that took care of the problem.
Re: Favorite / best timing light ? [Re: OUTLAWSSAA] #2479649
04/08/18 10:13 PM
04/08/18 10:13 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Craftsman chromie,or flaming river battery powered, best light's for the money for use with a multi spark ignition.
Re: Favorite / best timing light ? [Re: hemienvy] #2479791
04/09/18 03:19 AM
04/09/18 03:19 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Old craftsman chrome here.
Re: Favorite / best timing light ? [Re: hemienvy] #2479795
04/09/18 03:30 AM
04/09/18 03:30 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
The reviews of the Flaming River battery one on Amazon are far less than stellar.....It may work ok when it does, but reliability seems to be a problem.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Favorite / best timing light ? [Re: HemiRick] #2479818
04/09/18 07:34 AM
04/09/18 07:34 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Never had an issue with mine. Its a great light.
Re: Favorite / best timing light ? [Re: hemienvy] #2479834
04/09/18 09:04 AM
04/09/18 09:04 AM
pennsylvania
poboyengineering Offline
pennsylvania
I still use the old chrome light I bought at the parts store almost 40 years ago, it's never let me down. I just used it on the son's minivan to check a misfire, and I've used it on CNP engines too.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Favorite / best timing light ? [Re: hemienvy] #2479916
04/09/18 12:20 PM
04/09/18 12:20 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I’ve gone through two Flaming River lights shout
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Favorite / best timing light ? [Re: BloFish] #2479932
04/09/18 12:45 PM
04/09/18 12:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I really love my Flaming River light.. I'm on
my second light also.. one thing about them..
you CANT drive over them.. mine rolled under
the tire.. the wireless is great around fans
wave
Re: Favorite / best timing light ? [Re: hemienvy] #2479939
04/09/18 12:55 PM
04/09/18 12:55 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have the INNOVA digital dial-back timing light. It works with the MSD ignition. Have a chrome dial back also, but the MSD messes it up.
https://www.amazon.com/INNOVA-5568-Pro-Timing-Light-Tool/dp/B000EVU8J8/ref=sr_1_1?ie=UTF8&qid=1523285360&sr=8-1&keywords=equus%2Btiming%2Blight&th=1
Re: Favorite / best timing light ? [Re: 451Mopar] #2480792
04/10/18 10:40 PM
04/10/18 10:40 PM
my next one is gonna be a digital with a tach
