Page 1 of 3 1 2 3
22" aluminum radiator for 600+ horsepower. #2478707
04/07/18 07:15 AM
04/07/18 07:15 AM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
Has anyone had good luck with them? I've read that a 4 core Champion gets too hot. I've read ECP doesn't fit right. Does anyone have a positive experience with an aluminum 22" radiator for a fairly high horsepower engine that keeps their car cool?
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2478724
04/07/18 09:16 AM
04/07/18 09:16 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I just have a cheap aluminum universal radiator. It keeps my 575hp is iron small block cool. It probably wouldn't work if I wanted to run bonneville but for the street it does fine. I run a dodge intrepid dual fan setup and a meziere electric water pump.
68 Barracuda Formula S 340
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2478732
04/07/18 09:40 AM
04/07/18 09:40 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
I don't understand radiators and horsepower ratings. why would a radiator have a horsepower rating? I have two cars both with 22" radiators. one makes close to 500hp and runs cool and the other about 325hp and runs hot; so what's up with that if horsepower is relevant? i'd toss the horsepower stuff and look at more relevant issues to cooling.
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2478740
04/07/18 10:02 AM
04/07/18 10:02 AM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
I use the 22 alu radiator that Mancini sell but you need to fill out a form to have it made for your car ! If it matters to you i have a 505 rb hookt up to that radiator whit 600+hp and it works realy great combined whit a mr gasket 160f full flow termostat that results in 165-175f when driveing and it can idel forever ! I do use a hi flow mp water pump whit steel impeller also! Stan away from castingen impeller pump is my advice becas the are no good crap....
Re: 22" aluminum radiator for 600+ horsepower. [Re: lewtot184] #2478741
04/07/18 10:08 AM
04/07/18 10:08 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
You would really have to ask radiator manufacturers why they rate it by horsepower. When Champion's site says one radiator is "good to 400 horsepower", another is "good to 600 horsepower" and a 4 core is "good to more than 700 horsepower".
But why did I ask about horsepower? Well, my line of thinking was that to make more power, you're going to either need more cubes, more compression or more cylinder pressure. More cubes create more area to cool, more compression creates more heat, as does more boost. Gotta be a way to get that heat out, right? Like through the radiator? Which brings me back to my original question(s). Now that that's all out of the way, did you have a 22" radiator made of alumninum in anything with lots of cubic inches or lots of compression that was street driven that you kept under or at 180°? If so, what brand was it and how did it fit and what modifications did you have to make?
Thanks.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 22" aluminum radiator for 600+ horsepower. [Re: Mopar Guy] #2478745
04/07/18 10:16 AM
04/07/18 10:16 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I don't mind doing the paperwork. Thank you.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2478856
04/07/18 03:04 PM
04/07/18 03:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been running the same 22" Summit radiator forever and w/an elec. water pump and HHR fan, it cools my junk pretty well being I live in the HOT High Desert........... beer
Re: 22" aluminum radiator for 600+ horsepower. [Re: lewtot184] #2478976
04/07/18 07:28 PM
04/07/18 07:28 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
When you modify an engine to make more horsepower, you also increase the heat load on the cooling system.
Re: 22" aluminum radiator for 600+ horsepower. [Re: John_Kunkel] #2478986
04/07/18 07:52 PM
04/07/18 07:52 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
that's the basic assumption the marketers would spout. I don't buy it. how much time is spent at 600hp vs 60hp? it's all b.s. if more time was spent at 60hp vs 600hp would you buy a radiator 1/10 the size? of course not. vendors will say or do anything to sell something. there are too many other factors in cooling a water cooled engine than peak horsepower.
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2479017
04/07/18 08:49 PM
04/07/18 08:49 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
Here is a good read. Going thru the same thing for my son's Cuda. 22' or a 26" opening. www.saldanaracingproducts.com/Cooling%20System%20Principles.pdfstall
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 22" aluminum radiator for 600+ horsepower. [Re: Thumperdart] #2479018
04/07/18 08:50 PM
04/07/18 08:50 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I would run cooler with efi over a carburetor, right? gringrin
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2479037
04/07/18 09:08 PM
04/07/18 09:08 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
i use a universal thin alum Griffin radiator , 07' HHR fan , stock w/p , 160 t-stat. Car never gets hot
Re: 22" aluminum radiator for 600+ horsepower. [Re: 493_DART] #2479070
04/07/18 09:53 PM
04/07/18 09:53 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Copper '65 OEM with clutch fan. I don't even run a shroud.
'63 Dodge 330
11.19 @ 121 mph
Re: 22" aluminum radiator for 600+ horsepower. [Re: GY3] #2479076
04/07/18 09:58 PM
04/07/18 09:58 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I'm kinda kicking myself for selling the good 22" 053 radiator that kept the last engine cool.
Wait. Your car can't run cool. It doesn't have a thermostat...
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 22" aluminum radiator for 600+ horsepower. [Re: 493_DART] #2479078
04/07/18 10:02 PM
04/07/18 10:02 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have a Mancini 3 core in my Savoy and it cools great since I got my coolant flowing good through it. I'm using a good older pump where the impeller is close to the housing so it's more efficient. The pulleys have a huge impact on the flow as well. I had aluminum race pulleys on it and then switched to some factory ones and presto now it runs cooler.
Are you running hot on the highway or idling around town? Just saying maybe it's not the radiator shruggy I tried everything else before I changed my radiator and found a system that works for my mild(maybe 570) combo. My engine gets up to around 200 when I cruise around on 90 degree days but that is really not overheating.
Gus beer
64 Plymouth Savoy
Dana 60
Re: 22" aluminum radiator for 600+ horsepower. [Re: fourgearsavoy] #2479086
04/07/18 10:12 PM
04/07/18 10:12 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Gus beer
The car isn't on the road yet. I had the stock radiator in front of the Stealth headed 383 that was in it, and idling and 55-60 it never saw much over 185. When I got on 23 heading north and hit 70-75, it was up around 190.
I have a 440 Source pump and housing on the engine going in it. That's all the cooling system I have figured out so far.
I don't want to cut the core support for a 26". I haven't decide on mechanical or electric fans, although I'm leaning towards a clutch or flex fan.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2479097
04/07/18 10:31 PM
04/07/18 10:31 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My 434 small block is in the 650 hp range and I run a generic 22" aluminium radiator, a flow kooler pump, viscous fan, shroud and a 160° thermostat. Even with a small aluminium crank pulley I've never seen over 185° on the street or strip.
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2479112
04/07/18 10:51 PM
04/07/18 10:51 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Yep. LOL! realcrazy
I have the small Moroso crank pulley too. runaway
'63 Dodge 330
11.19 @ 121 mph
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2479119
04/07/18 11:00 PM
04/07/18 11:00 PM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
Stock 26" small block radiator, stock clutch fan and shroud in my hemi with a 180° thermostat and it doesn't get hot at all. It's got stock Chrysler pulleys too. I'd say it's got 580-600ish horsepower.
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2479121
04/07/18 11:02 PM
04/07/18 11:02 PM
Rittman Ohio
Rittman Ohio
Gus beer
I run the 440 Source steel pulleys and a 5 blade viscous MP fan with no shroud. If I put a shroud on it I could probably get my cruising around town temp down below 200. My highway temp used to be high over 200 until I put the 1 to 1 pulleys on it.
Gus beer
64 Plymouth Savoy
Dana 60
Page 1 of 3 1 2 3
