Re: WHERE TO BUY A GOOD.......
[Re: Magnumguy]
#2479138
04/07/18 11:19 PM
04/07/18 11:19 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
The ones that look like a "micrometer" are used for Chevy trucks to unload the tension off the bar. There are plenty of examples of homemade tools on the google search for "mopar" specific T-bars. The Mancini one looks good though Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Magnumguy]
#2479242
04/08/18 07:10 AM
04/08/18 07:10 AM
Posts: 4,848 Memphis
HemiRick
Memphis
I've never used one either....the whole idea is to not hurt the surface of the bar....many ways to grap one w/o hurting it.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2479282
04/08/18 10:48 AM
04/08/18 10:48 AM
RapidRobert
what works for me is to take off the wheels to lighten the assy & pry or tap the LCA rearward a bit to get the bar started rearward then tap the LCA forward till it comes off of the bar. A floor jack under the LCA to get it all supported/inline. If I was to clamp it I would ABSOLUTELY use some wood.
[Re: RapidRobert]
#2479329
04/08/18 12:15 PM
04/08/18 12:15 PM
Posts: 2,734 541 slobovia
A990
541 slobovia
what works for me is to take off the wheels to lighten the assy & pry or tap the LCA rearward a bit to get the bar started rearward then tap the LCA forward till it comes off of the bar. A floor jack under the LCA to get it all supported/inline. If I was to clamp it I would ABSOLUTELY use some wood. This is how I do it too. It works really well, besides, the LCAs have to be loosened to put it all back together.
[Re: 340Cuda]
#2479498
04/08/18 04:22 PM
04/08/18 04:22 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
If you need to buy the tool, the http://www.manciniracing.com/tobarreabceb.htmlclamp pictured above is the right one. The home made tool with u bolts werk just fine and does not mar the bar. It is a heck of a lot cheaper. I have removed them by releasing the tension in the control arm and tapping on the back of the bar with a drift. Some times they fight, other times, they fall right out.
I have mechanical Aptitude. I can screw up anything.
