Page 1 of 3 1 2 3
Low 10 second B body engine/trans big block combos. #2478459
04/06/18 07:29 PM
04/06/18 07:29 PM
Where else?
BigHemiVegas Offline OP
Where else?
I am looking to get a 1968 Dodge Charger into the low 10's or high 9's in the quarter. It will be all steel and most likely weigh around 3700. If you could post your detailed combo it would be appreciated. I did a search and couldnt find anything like this although I am sure it has been asked before. So if you have a link to combos then that would be great also.
Please be as detailed as possible.
What cubic inch RB, Hemi or Low Deck?
What brand block and what was prepped? Was block filled?
What cylinder heads,who ported them to what CFM and CC chamber volume?
Rocker arms,ratio and springs?
Intake,carb,spacer?
What headers?
Compression ratio using what pistons?
What stroke of crank and rods and brand?
Oiling system? Fuel system?
Transmission are you running?
What rear gear? Type of differential and axles?
What is your ET and MPH
Re: Low 10 second B body engine/trans big block combos. [Re: BigHemiVegas] #2478479
04/06/18 08:15 PM
04/06/18 08:15 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Looks like about 750hp to run 10 flat.
Have a great day
Iowan
"obsolete is neat"
Re: Low 10 second B body engine/trans big block combos. [Re: BigHemiVegas] #2478516
04/06/18 10:08 PM
04/06/18 10:08 PM
New York
polyspheric Offline
polyspheric  Offline
New York
There's easily $10,000 spread between different recipes.
What's the budget?
Boffin Emeritus
Re: Low 10 second B body engine/trans big block combos. [Re: BigHemiVegas] #2478521
04/06/18 10:14 PM
04/06/18 10:14 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Race only or street strip?
What suspension. I added more power to my car, but ET not that much better because using stock suspension.
Re: Low 10 second B body engine/trans big block combos. [Re: BigHemiVegas] #2478549
04/06/18 11:16 PM
04/06/18 11:16 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Lose about 1200 lbs, then run a 451 that makes 600hp. About the cheapest route.
Re: Low 10 second B body engine/trans big block combos. [Re: merpar] #2478561
04/06/18 11:41 PM
04/06/18 11:41 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Yep. That or add nitrous and spray it!
'63 Dodge 330
11.19 @ 121 mph
Re: Low 10 second B body engine/trans big block combos. [Re: BigHemiVegas] #2478619
04/07/18 01:07 AM
04/07/18 01:07 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Cast crank, stock rod 360, set of forged pistons, $125 regrind on the factory hydraulic roller, $700 turbo fed from stock exhaust manifolds. 10.08@136mph at 3700lbs with a 3.23 gear on street tires.
Most unconventional and cheapest way to do it for sure.
Re: Low 10 second B body engine/trans big block combos. [Re: dizuster] #2478631
04/07/18 01:20 AM
04/07/18 01:20 AM
fullmetaljacket Offline
Shave off the weight (easier said then done) and the motor will sweat less and last longer.
Ask me how I know.
Low deck or RB at or under 500 inches with a good head and extra good ring and head seal will jet that pup down stream quicker than you think, but it needs to have the fat trimmed.
Re: Low 10 second B body engine/trans big block combos. [Re: BigHemiVegas] #2478667
04/07/18 03:05 AM
04/07/18 03:05 AM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
My 71 fits your needs. I run 10 teens to 10.20’s at 4100 with me in it. Well I ran that till I found a cracked head and a scored cylinder a few weeks ago. Anyway here is the combo as it was.
4.30 Dana with a 29.5x10.5 M/T PBR. 727 with a low gear set and a 9.5” converter built by Lenny at Ultimate. It flashes around 5100. I leave off the brake at 3000. I have a alterkation front end and street lynx 4 link in the rear. Viking double adjustable shocks on all 4 corners. That is the basic drivetrain and suspension setup.
Motor. 400 low deck with a 4.375 bore and 4.25 stroke. I run C12 on 13.5-1 CR. Up top are Indy EZ-1 with a 2.25 intake valve. They flow 350 @ .700 I believe. 1.6 T&D rockers. Cam is a custom grind Comp solid roller. 268/276 @ .050. Lift is .721/.711 with the 1.6.
Single plane Indy Manifold with a 1050 Dominator on it. 2 1/8” TTI headers. Distributor is locked out at 36. I have a vac pump and electric WP. I do run P/S for the hydroboost and rack.
Motor made 838 HP on the dyno.
I have to put my 440 back in the car and figure out what I’ll do with the big motor. So won’t be running low 10’s this year. Dang.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Low 10 second B body engine/trans big block combos. [Re: BigHemiVegas] #2478719
04/07/18 08:50 AM
04/07/18 08:50 AM
UK
rb446 Offline
rb446  Offline
UK
If you don't want to be at 12>13:1 and race gas follow AndyF's 470 build, 10.5:1 775hp>
http://www.hotrod.com/articles/dyno-tested-vacuum-pump-help-engine-make-power/
Suggested chassis would be 5000stall, 31" tyre/4.56's and your ticket would look something like this if shocks etc. are up to the hit>
calculated at a race weight of 3800lbs@775fwhp actual on track power.
60 Foot E.T. : 1.38
1/8 Mile E.T. : 6.24
1/8 Mile Trap Speed : 108.86
1/4 Mile E.T. : 9.90
1/4 Mile Trap Speed : 135
1/4 Mile Trap RPM : 6,698+slip
However what something makes on a dyno and then at the track is another thing. I would aim for 800hp in your weight to be safe@9.90's.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Low 10 second B body engine/trans big block combos. [Re: BigHemiVegas] #2478787
04/07/18 11:55 AM
04/07/18 11:55 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If your screen name is an indicator of where you reside.... you're going to need some serious HP to get a 3700lb car into the 9's. While my Mirada had a pretty "basic" RB build, I was still just shy 500lb of your projected weight and ran a best of 10.28 in Vegas. I'm already seeing -1's or a B1 build in your future.... call me crazy.
....or go down the road of our resident "cheater" Dizuster laugh2 Boost would definitely be your friend.
Re: Low 10 second B body engine/trans big block combos. [Re: BigHemiVegas] #2478830
04/07/18 01:53 PM
04/07/18 01:53 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I'm in the middle of a similar street/strip build. 69 GTX Hope to get there with the aftermarket (the block) 505 wedge with Trick Flow 270 heads, Mopar 337 intake and a Dwayne Porter mechanical roller cam.
Re: Low 10 second B body engine/trans big block combos. [Re: BigHemiVegas] #2478832
04/07/18 01:59 PM
04/07/18 01:59 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I went 9.80’s at 135 ish with 650 horse at 3350
Adding 350 pounds on to run the same MPH is about 70 horse.
True 725 horse motor should get a 3700 pound car in the 9’s with no sweat. Should run 10 flat in the summer time
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Low 10 second B body engine/trans big block combos. [Re: BigHemiVegas] #2478836
04/07/18 02:09 PM
04/07/18 02:09 PM
IL
Dart451 Online content
Dart451  Online Content
IL
Hellcrate
Re: Low 10 second B body engine/trans big block combos. [Re: dizuster] #2478868
04/07/18 03:27 PM
04/07/18 03:27 PM
Where else?
Where else?
How much boost are you running? What size turbo? What pistons and what is your compression? What brand cylinder head? The cam duration and lift would be great to know as well. I wouldnt be going small block but it would be interesting to find out.
Re: Low 10 second B body engine/trans big block combos. [Re: Wookie316] #2478870
04/07/18 03:31 PM
04/07/18 03:31 PM
Where else?
Where else?
Are you running a stock block and what all preparation has been done to it? Did you use block fill?
Re: Low 10 second B body engine/trans big block combos. [Re: dizuster] #2478871
04/07/18 03:32 PM
04/07/18 03:32 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
With all due respect, that's a lot to ask of those stock parts. I hope you splurged on the safety stuff. luck
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Low 10 second B body engine/trans big block combos. [Re: dizuster] #2478880
04/07/18 03:42 PM
04/07/18 03:42 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
It took you a while to get there....Your kinda minimizing all the hard work, time, and learning you did in the process. Still an awesome build. Always wondered why you never ran Drag week with it.
Re: Low 10 second B body engine/trans big block combos. [Re: rb446] #2478881
04/07/18 03:45 PM
04/07/18 03:45 PM
Where else?
Where else?
60 Foot E.T. : 1.38
Awesome and thanks. That is a very interesting read.
Re: Low 10 second B body engine/trans big block combos. [Re: Dart451] #2478883
04/07/18 03:47 PM
04/07/18 03:47 PM
Where else?
Where else?
Originally Posted By Dart451
Hellcrate
This is actually toward the top of my list of options. I think they price out about 17K and it might just put me ahead of the game in my build.
Page 1 of 3 1 2 3
