Spark plug ? #2478313
04/06/18 01:59 PM
04/06/18 01:59 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
I have W2 heads and have been using RN9YC Champions. Would like to use RC9YC's for the smaller base. Is there any reason why I can't use them?
Re: Spark plug ? [Re: rt66jim] #2478332
04/06/18 02:43 PM
04/06/18 02:43 PM
Washington
madscientist Offline
Washington
Nope. I no longer use a 13/16 hex plug unless I absolutely have to do it.
The C and the N are exactly the same except for the hex.
Your life will be much easier with the C plug, especially with the W-2 head. The W-5 was even tighter.
Re: Spark plug ? [Re: rt66jim] #2478340
04/06/18 02:58 PM
04/06/18 02:58 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Thank you for your quick reply. Jim
Re: Spark plug ? [Re: madscientist] #2478389
04/06/18 04:53 PM
04/06/18 04:53 PM
So you can use the 5/8 hex plugs anywhere you are using the 13/16's. Correct heat range of course. Good info Madscientist!
Re: Spark plug ? [Re: rt66jim] #2478568
04/06/18 11:49 PM
04/06/18 11:49 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, the smaller hex is easier to deal with, more room at header flanges. Been using C59Y/C61Y (YC has different tip) race plugs for years, kinda spendy though. Batten W2s.
I also use the 5/8 hex on the BB motors, easy choice since their heads are usually aftermarket aluminum.
Re: Spark plug ? [Re: topside] #2478675
04/07/18 03:41 AM
04/07/18 03:41 AM
^^^ I'm sold.
