Re: 426 hemi starter
[Re: racerlall]
#2478739
04/07/18 10:00 AM
04/07/18 10:00 AM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
The same type of DD starter was used on other engines, and they're not interchangeable. There should be #s on the mounting flange. 66-67 Hemi was slightly different than 68-69 Hemi too. Perhaps you can try a dry mock up to confirm it's a 426 hemi starter?
68 Charger 70 Cuda
[Re: FC7cuda]
#2478796
04/07/18 12:04 PM
04/07/18 12:04 PM
Posts: 10,706 North Dakota
6PakBee
North Dakota
...66-67 Hemi was slightly different than 68-69 Hemi too.... Uh oh, I'm getting that sinking feeling. What is the difference?
[Re: 6PakBee]
#2478899
04/07/18 04:08 PM
04/07/18 04:08 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
...66-67 Hemi was slightly different than 68-69 Hemi too.... Uh oh, I'm getting that sinking feeling. What is the difference? Why are you getting a sinking feeling? Do you have a 170 tooth hemi flywheel motor? I had to come up with one of those starters back in 1991 for a car I was restoring for a lady, it was a 1969 Hemi Charger 500 4 speed car that was apart and missing the original starter, I ended up buying a used one from back east off of a 1966 Hemi Charger is what I was told it was from back then, it worked fine
[Re: racerlall]
#2478935
04/07/18 05:31 PM
04/07/18 05:31 PM
Posts: 8,236 fredericksburg,va
cudaman1969
fredericksburg,va
Wasn't that type used on the early Chrysler cars up to when the double-reduction starter came out? And industrial engines too.
[Re: FC7cuda]
#2479008
04/07/18 08:33 PM
04/07/18 08:33 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
66-67 Hemi was slightly different than 68-69 Hemi too. I believe the '66 (2642445) is different than the '67-69 (2642930).
[Re: Cab_Burge]
#2479563
04/08/18 06:42 PM
04/08/18 06:42 PM
6PakBee
North Dakota
...66-67 Hemi was slightly different than 68-69 Hemi too.... Uh oh, I'm getting that sinking feeling. What is the difference? Why are you getting a sinking feeling? Do you have a 170 tooth hemi flywheel motor? I had to come up with one of those starters back in 1991 for a car I was restoring for a lady, it was a 1969 Hemi Charger 500 4 speed car that was apart and missing the original starter, I ended up buying a used one from back east off of a 1966 Hemi Charger is what I was told it was from back then, it worked fine Cab, I have been buying parts for my 1967 Hemi GTX project for (no kidding) nearly forty years. It's a 4-spd so it has the direct drive starter. I was able to get one about 15 years ago that I believed would work as I thought '66-'69 were all the same. To read that there might be a difference between '66-'67 and '68-'69 just brought back the nightmare of me walking the earth trying to find a '66-'67 Dana. Nothing like hearing something you thought you were through with rears its ugly head. But if the difference is cosmetic, I'm not worried. Who can see the starter once installed anyway?
[Re: 6PakBee]
#2479582
04/08/18 07:37 PM
04/08/18 07:37 PM
John_Kunkel
Rio Linda, CA
Just because the starters are different doesn't mean they're not interchangeable; aftermarket starters are one-size-fits-all from '66-'69, the only time "different" matters is to the restoration-original crowd.
[Re: RobbMc]
#2482914
04/15/18 03:29 AM
04/15/18 03:29 AM
Posts: 82 Oly Wash
racerlall
Oly Wash
OK update I got the starter at the Portland swap meat thanks to all that helped nail it down as a hemi starter was comparing it to one iv had for a wile and thou might be a hemi starter not looking ouite right the one from Portland fits bell nice the one Iv had awile docent fit so well now supposedly the ones with the raises along the flange near the threaded bolt hole are hemi and the ones that are straight are slant 6 ones so what is the one Iv had for years fit hemi from Portland on the right
