Re: Manual steering shaft painted?
[Re: njmopar]
#2478692
04/07/18 05:31 AM
04/07/18 05:31 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Soak the shaft in EvapoRust. If it was painted black originally, you'll see black paint once it comes out of the dip. Even extremely rusted pieces probably have some hint of paint still on them.(under the rust) You'll be able to see it if you chemically remove the rust instead of blast it off. I'm ahead of you. Been soaking in Evapo since Sunday, will check tomorrow. Didn't look too promising for seeing paint though. I don't think it is painted. I think they were plated black phosphate and covered in a light machine oil. I would plate it and then put RPM on it.
