Advice from people who've used rust-oleum auto body paint
#2477752
04/05/18 08:55 AM
04/05/18 08:55 AM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
Im doing my first paint job and I really wanted to try this Rustoleum ready to spray base/clear line they have. Im not expecting miracles, this is more of an experiment. The victim is my nothing special 86 daily driver. If it turns out crappy, nothing lost and Im only out $200. Rustoleum and the Tech I talked to claim this paint is ready to pour into your gun and spray, there is no re-coat window, and no sanding or roughing up of the surface necessary between coats. It can be thinned with acetone if absolutely necessary. The clear coat I picked has metallic flake in it which I thought was pretty cool. I went ahead and bought: rustoleum auto body #253500 Jet Black Acrylic Base-coat rustoleum auto body #253521 High-gloss Metallic Clear-coat 2 of the $25 Harbor Freight spray guns. I started sanding with 800 grit, (400 grit in the worst rock chip areas, and a couple tiny bondo areas, which were then blended with finer and finer grit until matched with the rest) now I have it all up to 1000 grit where I've paused to get feedback about this paint before I continue. Guys and gals, has anyone used these? I read online that people say they didnt even change the tip in the harbor freight gun. What tip did you use? Did you thin? Did you wait a specific time between coats? How many coats of base and clear did you use? Did you sand between coats? What #grit(s) did you use, what was your final grit? Did you sand the clear? 68FBAC53-5267-4939-B5D4-AA71C59A7F08 by Richard Bailey, on Flickr
Re: Advice from people who've used rust-oleum auto body paint
[Re: Adam71Charger]
#2477816
04/05/18 11:52 AM
04/05/18 11:52 AM
DaytonaTurbo
Manitoba, Canada
Their product is non-catalyzed which means it never really hardens and will scratch easy and always be susceptible to solvents like gasoline. I have used a product like that before thinking I was going to save money or do something easy but I was never happy with it. I was never tough enough, scratch resistant enough and I could damage it with my thumb nail. Also if you try to sand it down later it will glob up your sandpaper making a huge mess. The globs will stick to your sandpaper and make gouges into the paint making more and more of a mess. The only way I could clean it up was to carefully wet sand it, frequently cleaning my sandpaper and surface. A proper product will include p-sheets that will answer all of your questions. In the past I have used the restoration shop and kustom shop products sold by www.tcpglobal.com with good results. They have p-sheets on their website which tell you all the pertinent info like mix ratios, compatible substrates, surface prep, grit, application techniques, gun tip size and air pressure, etc. Their gallon kits of single stage urethane prepackaged colors are like $120 each and layed down real smooth even with my cheapie spray gun. I thought my results were kind of hum-ho until I went into the chevy dealer for parts for work one day and noticed how much smoother my single stage job was than the OEM clear coat on the corvette and camaros they had in their showroom! I'm just a backyard hack but the only time I have prepped with 1000 grit has been if I've been scuffing base coat to re-clear an existing panel. Normally I do 400 before hosing on the single stage paint.
[Re: Adam71Charger]
#2477822
04/05/18 11:59 AM
04/05/18 11:59 AM
Adam71Charger
MoJoe,
I believe You are referring to the 'tremclad' method originally posted here on moparts. Ive painted multiple vehicles this way. You use Rust-Oleum oil based enamel from the hardware store, thin it just right with mineral spirits, then use a 6" foam roller and start rollin the paint on. You have to do a minimum 2 coats for every step of wet sanding. For example I sanded my Polara down to 600, rolled on a couple coats, waited 48 hours minimum, sanded with 800, 2 coats, 1000, 2 coats, 1500, 2 coats, 1800. Then cut and polish, buff. It takes a couples weeks for me Im sure others do it much faster Im just slow and OCD.
I'm not doing the roller method anymore, I want to try spraying. I was looking for a cheap and entry level base-coat/clear-coat when I found this product line from Rust-Oleum. I did a little research and besides the painters who automatically say negative things when they hear the word rustoleum, there was pretty good feedback especially from amateurs which i paid most attention to. People who actually spent some 'warm up' time practicing and playing around with pattern and dry time etc said they got really good results (for $18 a quart paint.)
Im looking forward to trying it out
[Re: Adam71Charger]
#2477826
04/05/18 12:04 PM
04/05/18 12:04 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
I suspect this product is very much like the Duplicolor and Summit Racing ready to spray systems. Definitely bottom line as far as quality goes, but you can do a fairly decent job with any of them. That said, don't expect the paint job to last very long since these paints aren't designed for that. They're designed to be easy to spray, not for durability.
Also... do NOT sand to 1000 grit and expect paint to stick. For a non metallic base coat sand to 400 grit and for a metallic sand to 600 grit. The paint needs mechanical adhesion and 1000 grit scratches aren't big enough to allow the paint to adhere to the surface properly. Otherwise it will just peel off in a few weeks.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: Centerline]
#2477834
04/05/18 12:19 PM
04/05/18 12:19 PM
Adam71Charger
Also... do NOT sand to 1000 grit and expect paint to stick. For a non metallic base coat sand to 400 grit and for a metallic sand to 600 grit. The paint needs mechanical adhesion and 1000 grit scratches aren't big enough to allow the paint to adhere to the surface properly. Otherwise it will just peel off in a few weeks. Interesting, I thought that automotive paint was meant to be sanded in stages ending in super high/fine grit?? For base coats are you just supposed to lay on a ton of coats then sand down to super fine before spraying clear? At what point are you supposed to smooth out those deep 400 grit scratches?
[Re: Adam71Charger]
#2477839
04/05/18 12:31 PM
04/05/18 12:31 PM
DaytonaTurbo
Manitoba, Canada
With real automotive paint, you don't sand between the base coat and clear coat. The p-sheets for the base and clear will tell you how long you can wait between applying the base and applying the clear. Proper paint will lay right on top of that 400 grit surface and not display any scratches through the top coat.
[Re: Adam71Charger]
#2477857
04/05/18 12:53 PM
04/05/18 12:53 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I know this isn't what you want to hear.... But as someone who paints multiple cars every year, it's not even a paint I'd consider using, especially for $200... I'd use some kirker single stage urethane, summits brand and other for that price. For a little more you could get some omni/nason base and clear and have a way better paint job when done. Too much work to paint a vehicle to have it look like crap in a year or so.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Adam71Charger]
#2477881
04/05/18 01:41 PM
04/05/18 01:41 PM
Adam71Charger
Daytona Turob,
Are we talking about the same paint?? the Rustoleum Oil Based Enamel I rolled on took awhile to fully 'cure', like months, but once it did it was incredibly durable. Have you read the gigantic Tremclad thread here on moparts? I believe it's archived. Tremclad is the Canadian name for the same rustoleum oil based enamel paint. I painted my sisters nova like 4 years ago, and besides dulling a bit, which cleared up with a quick polish, its been the toughest paint Ive ever seen. Not even any rock chips, and she has/had gasoline spills all the time and there's been no effect except a very light and tiny discoloration from the worst area where gas will stream down when gas overflows. You cant dent the paint with a finger nail at all, you gotta press firmly with a key to make a mark ( I tested an inconspicuous area). I also painted my Polara and also a Ram. The only thing I didnt like about the paint was the color selection, I could never master the technique, and I just dislike single stage paint.
Silver70,
are you saying the clear coat dulls/discolors over time? could I just use a different clear coat over the rustoleum base coat?
[Re: Silver70]
#2477893
04/05/18 01:57 PM
04/05/18 01:57 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
it's not even a paint I'd consider using, especially for $200... I'd use some kirker single stage urethane, summits brand and other for that price. For a little more you could get some omni/nason base and clear and have a way better paint job when done. Too much work to paint a vehicle to have it look like crap in a year or so. Thank-You...
[Re: Adam71Charger]
#2477898
04/05/18 02:06 PM
04/05/18 02:06 PM
Adam71Charger
2 guns actually
**and another 25ish of that was shipping costs
it was the cheapest option I could find at the time and it seemed like the most forgiving paint regarding sensitivity to tip sizes, moisture content in the air and the temperature at which it's sprayed at.. I think I did ok for having zero experience spray painting, and barely minimum knowledge about paint lol. We'll see how it goes!
[Re: Adam71Charger]
#2477904
04/05/18 02:23 PM
04/05/18 02:23 PM
DaytonaTurbo
Manitoba, Canada
Daytona Turob,
Are we talking about the same paint?? the Rustoleum Oil Based Enamel I rolled on took awhile to fully 'cure', like months, but once it did it was incredibly durable. Have you read the gigantic Tremclad thread here on moparts? I believe it's archived. Yes we are talking about the same stuff. I was on the board here when that tread was ongoing. Yes it's durable, compared to spray paint. Still sub-par. I dislike base/clear in general, I have spent too much time fixing peeling clear done by other backyard hacks so for solid colors I stick with single stage and only use base/clear for metallics or repairing existing clear coat. I have found generally that the budget line auto paint systems are reasonably priced these days so that an extra 100 bucks upgrades you out of the hardware store aisle. Bottom line, you have the product and you're going to use it. For the same money you could have got something significantly better, not mention the time and effort that could have been saved.
[Re: Adam71Charger]
#2477937
04/05/18 03:12 PM
04/05/18 03:12 PM
Posts: 956 Chicago
PurpleBeeper
Chicago
Hey Adam, a few things I will throw in.
1. You cannot add hardener to a paint not designed for it, so forget about that. 2. You "might" be able to improve your durability with a 2-component (with hardener) style clear coat, but I would strongly suggest that you test a small piece of metal first (before you paint your car) to see exactly how it will affect the basecoat you have. 3. I think I responded over on FBBO to this as well (?). 1-component enamels are somewhat like the old school lacquer paints. They don't have the chemical resistance like 2-component paints (do watch out for gasoline spills), but you might get decent results. 4. I didn't realize that Rustoleum is now making automotive paint.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: DaytonaTurbo]
#2477945
04/05/18 03:39 PM
04/05/18 03:39 PM
Adam71Charger
Daytona Turob,
Are we talking about the same paint?? the Rustoleum Oil Based Enamel I rolled on took awhile to fully 'cure', like months, but once it did it was incredibly durable. Have you read the gigantic Tremclad thread here on moparts? I believe it's archived. Yes we are talking about the same stuff. I was on the board here when that tread was ongoing. Yes it's durable, compared to spray paint. Still sub-par. I dislike base/clear in general, I have spent too much time fixing peeling clear done by other backyard hacks so for solid colors I stick with single stage and only use base/clear for metallics or repairing existing clear coat. I have found generally that the budget line auto paint systems are reasonably priced these days so that an extra 100 bucks upgrades you out of the hardware store aisle. Bottom line, you have the product and you're going to use it. For the same money you could have got something significantly better, not mention the time and effort that could have been saved. Im definitely not trying to defend rustoleum just cause I bought it already, I knew it wasnt great, and was prepared for some poor reviews but I didnt know it was as bad as you guys are telling me... Which still doesnt necessarily change my mind about using it. What is sticking in my brain though is that you guys are telling me I could get something of much better quality for similar price. I still have my receipts so if it truly is this terrible I can send it all back. Do you have any other suggestions for a Dark Black 2 stage kit for around $200-300 total, other than whats been posted already?
[Re: Adam71Charger]
#2477969
04/05/18 05:39 PM
04/05/18 05:39 PM
DaytonaTurbo
Manitoba, Canada
The website linked in my first reply.
