EFI conversions...FAST? FiTech? Holley Sniper...MSD? #2477457
04/04/18 05:03 PM
04/04/18 05:03 PM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
Has anyone been successful with converting to self tuning EFI with a long duration (250 +/- @ .050) cam??
We have a FAST 2.0 on 1 car, it idles right at 10", but we think the EFI isn't always happy. This a 242/244 @ .050 cam, 110 LSA
The next project's cam is 244/252 @ .050, (110 LSA) and I'm having my doubts about my first choice in the FAST EZ EFI due the 10" vacuum needed.
Some kits declare 8-10" required...
Anyone have any experiences/advice to share?
Thanks!
Re: EFI conversions...FAST? FiTech? Holley Sniper...MSD? [Re: cudadoug] #2477468
04/04/18 05:20 PM
04/04/18 05:20 PM
AndyF Offline
AndyF  Offline
I recommend an EFI system which you can tune with a laptop. That way if the stock settings don't work you can either hook up your own laptop to the ECU or take it to a tuner.
I just spent some time this morning helping a local guy who has a Holley Terminator system. His idle speed was hanging up and there is no way to fix that from the handheld device. I was able to plug my laptop into his system and adjust the IAC hold percentage and that fixed the problem.
Holley Sniper has laptop access but I don't think the FiTech does. I don't think MSD has laptop access either. You'll have to check on FAST, might depend on which setup you buy.
Re: EFI conversions...FAST? FiTech? Holley Sniper...MSD? [Re: cudadoug] #2477476
04/04/18 05:52 PM
04/04/18 05:52 PM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
I have the FAST XFI SPORTSMAN, love it, it’s only laptop tunable but very easy to use, you can sit at the coffee table and build a tune or modify the existing, plug it in, two seconds later your new tune is in and running, or have a street tune and a track tune, simply drive to the race track, load the more fuel and timing tune for racing and go race, put the street tune back in it to go home on a less aggressive tune about town. if you have a low vacuum engine due to a cam you pretty much almost have to use a laptop tunable system.
Re: EFI conversions...FAST? FiTech? Holley Sniper...MSD? [Re: crash520] #2477511
04/04/18 07:23 PM
04/04/18 07:23 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Big cams are tough, the IAC settings get tricky with the gain and amount right. I had a .738 lift cam with 283* duration at .050 in a 484 Hemi.
It was a pain to get the engine to idle well and transition well without surging. In gear vs. out of gear, & cruise vs quick stop. Essentially I used the IAC settings as low as possible without adding fuel as rpm varied a little. Need to set the throttle blades to get some air without the IAC. I messed with this when the timing curve wouldn't keep it from surging. My throttle blades were big and made this very touchy...
So FAST 2.0 or Holley Dominator, maybe the XFI sportsman...Yes you want a laptop tuneable one.
https://www.youtube.com/watch?v=9tHA9t2U8-Y
https://www.youtube.com/watch?v=-AXRHXSV5Jc
Re: EFI conversions...FAST? FiTech? Holley Sniper...MSD? [Re: cudadoug] #2477524
04/04/18 07:35 PM
04/04/18 07:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run a SB and the cam is a fair bit bigger
than your specs.. its a Holley HP unit and
I use the labtop to tune.. I had a lot harder
time tuning with a big solid roller
wave
Re: EFI conversions...FAST? FiTech? Holley Sniper...MSD? [Re: cudadoug] #2477534
04/04/18 07:57 PM
04/04/18 07:57 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I have a FITech on my 493 with a 260/266 @ 050 cam.
It doesn't have an option to go open loop or Alpha/N in idle, but with some trickery I got it to clean up at idle. FITech does have software to tune via laptop, I will say the software sucks, and they explicitly do not support any tuning you want to do on your own, and they don't document things very well either.
Next car will get proper MPI with a Holley ECU
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: EFI conversions...FAST? FiTech? Holley Sniper...MSD? [Re: cudadoug] #2477535
04/04/18 08:01 PM
04/04/18 08:01 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Mine is stone age by comparison but getting a consistent idle with a 509 248@.050 in closed loop was impossible. It's an old Commander 950 system but it had the option of switching between alpha numeric and closed loop. Once it got over 1800 RPM on A/N, it was happy to run on the map closed loop.
Kevin
Re: EFI conversions...FAST? FiTech? Holley Sniper...MSD? [Re: cudadoug] #2477550
04/04/18 08:45 PM
04/04/18 08:45 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Tough love...
If you don’t want to tune yourself, put a smaller cam in. There is no 100% perfect self tuning system for larger cam engines. Maybe someday, but not now.
Holley’s hp/ dominator systems impress me, but even on a stock engine, some manual tuning with a laptop is needed for a perfected tune/ driveability. Not to say that a Holley on a stock engine doesn’t run extremely nice, just not perfect.
The fast system should be perfectly capable on any engine/ cam combo with some laptop attention.
Re: EFI conversions...FAST? FiTech? Holley Sniper...MSD? [Re: cudadoug] #2477557
04/04/18 08:57 PM
04/04/18 08:57 PM
cudadoug Offline OP
cudadoug  Offline OP
Good stuff, guys. I appreciate this. The FAST 2.0 was my first exposure to this EFI world, so I'm "self learning" too.
Re: EFI conversions...FAST? FiTech? Holley Sniper...MSD? [Re: cudadoug] #2477613
04/04/18 10:49 PM
04/04/18 10:49 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Holley HP system if Multi-port, or Holley Terminator if you are looking for a TBI setup(Terminator uses the HP ECU).
The only Carbs I care about are under the hood!
Re: EFI conversions...FAST? FiTech? Holley Sniper...MSD? [Re: cudadoug] #2477616
04/04/18 10:54 PM
04/04/18 10:54 PM
AndyF Offline
AndyF  Offline
The new Super Sniper should be a good system too and less expensive than a multiport setup. The Holley Terminator is a good system that is fairly easy to install. But you'll need a laptop, an ECU cable and the software to really dial in a performance engine.
The local guy I've been helping out has an LS crate engine with a fairly mild cam and his Terminator system has required a few trips to a tuner. If he had a radical cam in there then he would be paying a lot to get it tuned.
Re: EFI conversions...FAST? FiTech? Holley Sniper...MSD? [Re: cudadoug] #2477707
04/05/18 01:54 AM
04/05/18 01:54 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Turn the self learning off after you dial in the fuel map.
I use XFI 2.0 on both my cars. .800 lift with 285 at.050 and the other is about .650 lift but I forget the at .050.
Where u located
Re: EFI conversions...FAST? FiTech? Holley Sniper...MSD? [Re: FastmOp] #2477764
04/05/18 09:49 AM
04/05/18 09:49 AM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
Where u located
I might have to pick your brain from time to time FastmOp, I’ve got the XFI 2.0 Sportsman on my stick 340 but am about to swap to a cranky solid roller W2 408. I’m still very new at EFI tuning
Greg
Re: EFI conversions...FAST? FiTech? Holley Sniper...MSD? [Re: crash520] #2477925
04/05/18 02:53 PM
04/05/18 02:53 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I installed a Holley Terminator EFI on a 318/390 stroker. It had a hydraulic flat tappet cam with 239º/246º @ .050. The Terminator had no issue with the cam duration. After driving it for a while, the engine idled great, and throttle response was razor sharp.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: EFI conversions...FAST? FiTech? Holley Sniper...MSD? [Re: OUTLAWD] #2477949
04/05/18 03:56 PM
04/05/18 03:56 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
i just put the FiTech Go8 1200 on the Charger just to see if it would run on an engine with big cam. The Charger has the 500" stroked 400, 12.4:1 compression, Hughes ported Victor MW heads, Comp HXL lobe solid roller 272/278 @ 0.050, 110 lsa, 0.726"0.726" lift. About 4-5" vacuum at idle.
I just tried the swap from carb to TBI EFI about 3-weeks ago using a temporary fuel system. Initial startup and idle looked like it will work, so I got the in-tank retro-fit EFI pump and adapted my old fuel system to the new system. I also got the timing control to work with a lean-burn distributor. I think one of the biggest factors with these self-learning systems is no exhaust leaks and full exhaust system so fresh air can not mess up the wide band O2 readings?
I have only drove the car about 30-miles, but it seemed to self-learn when driving, and does run good, but still working on the idle system.
Right now I have idle set a bit high at 1,300 RPM, and made a few adjustments to the idle mixture, idle ignition advance, and increased the idle trim rates a bit. I need to make a few adjustments for return to idle as it takes a bit of time for the idle to come back down, but it is not that bad.
The FiTech "power adder" versions come with the laptop software where you can tune with a laptop. I think the non-power adder versions can do this also, but you have to download the software from FiTech. I think they want to obscure the actual EFI control with simplified user software and instructions.
Holley has a "Super Sniper" TBI that looks really nice, has some additional features, and is priced the same as the FiTech. Their software is more traditional EFI menus and they have better instruction manuals and videos. I haven't used one, but have heard good things about the regular Sniper TBI system.
