Help IDing this 15X6 JJ Wheel? #2477299
04/04/18 11:08 AM
04/04/18 11:08 AM
VA
dragon slayer Offline OP
VA
Can someone help tell me what his wheel came from? Kelsey Canada has Penstar. K2 0 May Wheel. Solid rim. Thank you,
Re: Help IDing this 15X6 JJ Wheel? [Re: dragon slayer] #2477346
04/04/18 12:27 PM
04/04/18 12:27 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The solid rim centers were for HD applications like A35 - Trailer towing as an example.
My 1970 Fury III with A35 still has its matching set of 5.
Re: Help IDing this 15X6 JJ Wheel? [Re: dragon slayer] #2477360
04/04/18 01:00 PM
04/04/18 01:00 PM
VA
VA
Thank you, The extra hole is for? Also was there any rhyme or reason to the center pattern? 3 nub, versus 4 and orientation? Or was that just a factory that made them thing?
Re: Help IDing this 15X6 JJ Wheel? [Re: dragon slayer] #2477365
04/04/18 01:11 PM
04/04/18 01:11 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Could be? Mine were made in the US & do not have the extra small hole.
I have another one I picked up, I'll go check it just for fun........
Re: Help IDing this 15X6 JJ Wheel? [Re: dragon slayer] #2477377
04/04/18 01:36 PM
04/04/18 01:36 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
OK, the other one I have is also a Kelsey Canada & it has the extra hole in the hub.
Re: Help IDing this 15X6 JJ Wheel? [Re: Alaskan_TA] #2477437
04/04/18 04:17 PM
04/04/18 04:17 PM
VA
VA
Any idea what it is for?
Re: Help IDing this 15X6 JJ Wheel? [Re: dragon slayer] #2478142
04/06/18 12:08 AM
04/06/18 12:08 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I believe the extra hole is to attach a bracket that is required for attaching some wire wheel or other full size wheel cover?
