Re: Fi tech fuel system
[Re: BDW]
#2477090
04/03/18 10:52 PM
04/03/18 10:52 PM
Posts: 1,945 roanoke va
kbcuda
roanoke va
Check RockAuto, they carry Spectra tanks in tank pumps and baffling. Installed in my Challenger with 600HP FiTech system and it works great. Least expensive, cleanest solution I could find. As a complete assembly or individual parts?
[Re: BDW]
#2477160
04/04/18 12:43 AM
04/04/18 12:43 AM
Posts: 53 PA
Cudaful
PA
Check RockAuto, they carry Spectra tanks in tank pumps and baffling. Installed in my Challenger with 600HP FiTech system and it works great. Least expensive, cleanest solution I could find. I have one for my Cuda but it was like 2-3 years ago at least, when they first came out and if I remember when I looked at it, it didn't have a flare fitting on the fuel line coming out of the sending unit/pump assembly. Does yours?
[Re: BDW]
#2477353
04/04/18 12:48 PM
04/04/18 12:48 PM
Posts: 1,822 Colorado
denfireguy
Colorado
To me the best reason for using the Spectra Tank system is that it uses the OEM vapor separator/vent system. Been using mine since they came out. Also from Rock as the distributors either did not have them or had a very high opinion of its pricing. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: kbcuda]
#2477492
04/04/18 06:49 PM
04/04/18 06:49 PM
Posts: 10,502 Chicago, Illinois
Devil
Chicago, Illinois
I do not know if they make them for A-bodies yet. I've only seen them for B/E-Bodies so far. I did the same thing, with a Rockauto Coupon I got my 71 Challenger EFI tank for just over $200. https://www.rockauto.com/en/catalog/dodge,1971,challenger,7.2l+440cid+v8,1496987,fuel+&+air,fuel+tank+&+pump+assembly,17130 There is this intank A-body tank with pump. http://www.tanksinc.com/index.cfm/page/p...prod/prd481.htmAnd intank is always better then outside, helps keep the pump cool and lasts longer.
[Re: kbcuda]
#2477531
04/04/18 07:53 PM
04/04/18 07:53 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
While the FITech reg is a little small, it handles a 340 lph pump no problem.
I just tapped one of the -6 plugs for a gauge to verify. You can also run an external reg if you block the return...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: BDW]
#2477653
04/04/18 11:53 PM
04/04/18 11:53 PM
Posts: 53 PA
Cudaful
PA
Ok, I was worried about using clamps for high pressure hose. Spectra tank comes with baffling, in tank electric fuel pump and sending unit at a single price for $250. Used fuel injection hoses and clamps to hook up to the tank.
[Re: KillerBee]
#2477776
04/05/18 10:31 AM
04/05/18 10:31 AM
Posts: 4,753 Florida
BDW
I said $250, it was $258. RockAuto always has 5% off coupons and doesn't kill you on shipping. It's been a year, here's my order. Summit gives "free" shipping by raising the price......
[Re: BDW]
#2477884
04/05/18 01:45 PM
04/05/18 01:45 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
I noticed you ordered the CR8DFI Spectra tank from Rockauto and the tank Summit lists is the Spectra CR8FFI.
Anyone know the difference between the CR8DFI and the CR8FFI? Big difference in price, is there a difference in the pump?
They both appear to be for Challengers, would it be model year difference?
https://www.rockauto.com/en/parts/spectra+premium/cooling+depot,CR8DFI,fuel+tank+&+pump+assembly,17130
https://www.rockauto.com/en/parts/spectra+premium,CR8FFI,fuel+tank+&+pump+assembly,17130
