10 Point Cage -- -Do`s and Don`ts
#2476922
04/03/18 06:26 PM
04/03/18 06:26 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Have an appointment to have a 10 point cage put in my `Cuda. DOM 1-3/4" tube I want swing-out bars on both sides since it will probably see limited street use in the future. It is being bent on location,NOT a kit. Bars will go between windsheild and dash as tight as possible to the pillar. I think the rear struts should go to the shock cross member{coil-overs}. 1st experience letting ANYONE touch my car in 37 years. current rollbar I put in in 1986.
Opinions/Advise???
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
Re: 10 Point Cage -- -Do`s and Don`ts
[Re: Dart451]
#2476931
04/03/18 06:47 PM
04/03/18 06:47 PM
6bblFLASH
N.E. Ohio
Thought cage could be 1 5/8" tubing You might be right. Haven`t discussed with him yet. I`ve seen kits both ways. 1-3/4' was an assumption,probably a wrong one. Chromemoly is probably not an option.but I will ask him. 1-5/8' would be nicer.
[Re: topside]
#2476955
04/03/18 07:20 PM
04/03/18 07:20 PM
Posts: 4,457 Washington
madscientist
Washington
Bring an NHRA rulebook printout with you. I'm with you on the cage being tight to the pillars; much more professional and easy to see around. On my Duster, the forward bars are in the fender wheelhouses so they're not in the engine compartment; they tie to the shock tower reinforcements. This^^^^^^^^^ make sure you have a copy of the rule book with you, and then verify EVERYTHING before you pay for it. That includes sonic testing the tubing and verifying the bars are in the correct location.
[Re: 6bblFLASH]
#2476958
04/03/18 07:27 PM
04/03/18 07:27 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
FWIW when I did my E body Cuda years and years ago we did the a pillar bars tight and through the dash. We also ran the rear bars up against the roof to allow for clearance to the rear seat as well. Since mine was more a street car than racecar, although it ran 9's with the blower motor in it.
[Re: dvw]
#2477020
04/03/18 08:42 PM
04/03/18 08:42 PM
6bblFLASH
N.E. Ohio
My car has an aluminum dash for now. Eventually I would like something more stock looking, probably fiberglass.
[Re: Biginchmopar]
#2477045
04/03/18 09:26 PM
04/03/18 09:26 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Why 1 3/4"? Roll cage right? I would go 1 5/8"
Another thing to think about is going to Chromoly, the cost between DOM and Chromoly is negligible. Yes you have to TIG Chromoly so that might play into it.
To make the bars as tight as can be will be pretty difficult. Without cutting the car it is dam hard to weld the joints on the roof line completely. There are construction methods that can be used to get the bars up and out tight. Taking the windshield out can help with getting the A pillar and eyebrow bar or halo in. Don't forget frame ties if they need to be included or up graded. Tight fits and clean detailing takes time. Time is money. If you have to take a rule book along and tell the guy how to do it, are you sure you picked the right guy? He should be telling you.
[Re: 6bblFLASH]
#2477050
04/03/18 09:43 PM
04/03/18 09:43 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
Mine is c.m. and goes through the top of the dash. Notched dash back around the A pillar bars. We tacked all of the main structure in the car. Then spilt it where the rear portion of the A pillar bars ties into the main hoop. Welded everything up 100% outside of the car except at the split. Placed back in car and welded those two spots.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6bblFLASH]
#2477069
04/03/18 10:16 PM
04/03/18 10:16 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
I used CM years back when it was required to have one.My only regrets are not going through the dash or installing a diagonal bar overhead for a parachute release handle.
[Re: 6bblFLASH]
#2477217
04/04/18 02:25 AM
04/04/18 02:25 AM
Posts: 1,102 Massillon, Ohio
cudatom
Massillon, Ohio
Dennis nice to see you are working on the Cuda again. I dropped my Cuda off for a redo last month. I am going with CM. Like others said price difference was minimal.
I will be checking the status when I get home next week.
Ok
[Re: 6bblFLASH]
#2477280
04/04/18 10:19 AM
04/04/18 10:19 AM
Posts: 4,209 New York
polyspheric
New York
1-3/4" has 27% more bending resistance than 1-5/8", weighs 8% more.
There are 3 reasons why a cage: 1. pass tech 2. safety 3. chassis response
The same plans are not equally effective in all 3.
Boffin Emeritus
[Re: CMcAllister]
#2477428
04/04/18 03:41 PM
04/04/18 03:41 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
To make the bars as tight as can be will be pretty difficult. Without cutting the car it is dam hard to weld the joints on the roof line completely. There are construction methods that can be used to get the bars up and out tight. Taking the windshield out can help with getting the A pillar and eyebrow bar or halo in. Don't forget frame ties if they need to be included or up graded. Tight fits and clean detailing takes time. Time is money. If you have to take a rule book along and tell the guy how to do it, are you sure you picked the right guy? He should be telling you. I know all about it: 6.0 Cert
[Re: polyspheric]
#2477474
04/04/18 05:40 PM
04/04/18 05:40 PM
Posts: 4,687 Wichita
GY3
Wichita
The same plans are not equally effective in all 3. Serious questions: Do you even own a racecar? Have you ever raced a car?
[Re: 6bblFLASH]
#2477844
04/05/18 12:34 PM
04/05/18 12:34 PM
polyspheric
New York
I missed the ceremony in which you were given supreme authority to approve credentials. Apparently those comments are both strange and frightening to you. You're right, I'm 12, and ride a bicycle, which means I must be wrong. Exactly what part of my remark is error?
Boffin Emeritus
