Need information on '98 1 ton 4WD front hubs and suspension #2473320
03/28/18 02:21 PM
03/28/18 02:21 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
I have a 1968 Dodge crew cab that I am planning to convert to a 1 ton Cummins powered camper hauler/race trailer tow rig.
I was planning to go two wheel drive, but I just picked up a 1998 Ram 3500 four-wheel drive diesel donor truck. I see that the front axle is suspended via some type of 4-link suspension. Are these much good? Do they drive true and straight down the road and ride okay? Are they reliable? My other question is how do the front hubs operate? There is a shifter on the floor for the transfer case but I don't see any means of locking or unlocking the front hubs. Any information or advice would be appreciated. Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Need information on '98 1 ton 4WD front hubs and suspension [Re: Hemi_Joel] #2473530
03/28/18 08:53 PM
03/28/18 08:53 PM
Guitar Jones Offline
There is no unlocking mechanism for the front hubs from the factory. The axles turn all the time. There are aftermarket kits to convert them. I did one of my trucks but for the $2K price I would say it wasn't worth it.
The coil spring suspension rides better than the old leaf spring design. Ball joints are weak links though.
Re: Need information on '98 1 ton 4WD front hubs and suspension [Re: Guitar Jones] #2474830
03/31/18 12:05 PM
03/31/18 12:05 PM
Mesa , Az
Jambbii Offline
Jambbii  Offline
Mesa , Az
The track bar needs to be upgraded as well. The front hubs are sealed units you can convert them to free spin as well but it is pricey.
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
Re: Need information on '98 1 ton 4WD front hubs and suspension [Re: Hemi_Joel] #2474834
03/31/18 12:11 PM
03/31/18 12:11 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I'm not sure there has ever been a 3500 4x4 that tracks/drives true down the road.
Re: Need information on '98 1 ton 4WD front hubs and suspension [Re: Hemi_Joel] #2474878
03/31/18 02:04 PM
03/31/18 02:04 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Save yourself alot of grief and find a 2wd.
I have several 2nd Gens 4x4's and while that front-end rides nice, steers excellent, handles well and looks great, something will always go wrong, from most frequent:
1. Outer axle u-joints.
2. Axle seals.
3. Hub bearings
4. Ball joints
And pulling all this stuff apart isn't easy, especially the axle seals and hub bearings.
If you want to stick with what you have, there is a way around most of it, and I'm thinking seriously about this on my next project: Pull the outer drive axles, inside axles, the crown and pinion, and front drive shaft. Weld a cap on the ends of the axle tubes, and run it as a 2wd.
4wd is for People who don't know how to drive. twocents
Mo' Farts
Moderated by "tbagger".
Re: Need information on '98 1 ton 4WD front hubs and suspension [Re: Hemi_Joel] #2474951
03/31/18 05:19 PM
03/31/18 05:19 PM
Minnesota
Minnesota
Thanks for all the advise. I think I'll just stick with the I-beam 2 wheel drive front axle and parallel Leafs. I want to keep it simple.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Need information on '98 1 ton 4WD front hubs and suspension [Re: Hemi_Joel] #2475162
04/01/18 01:38 AM
04/01/18 01:38 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
My son has an 02 with the part time hub conversion, it is basically just Ford stuff that makes up the kit. It doesn't gain you any MPG with a diesel it just helps keep a few parts from wearing out.
Sheldon
Re: Need information on '98 1 ton 4WD front hubs and suspension [Re: Hemi_Joel] #2476477
04/02/18 09:52 PM
04/02/18 09:52 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
find a first gen cummins and grab the front dama 60 and the rear dana 70---might be easier to use a 89-91 non intercooled motor from the same unit----no room for an intercooler on your truck and not much space for the fan clutch either....
Re: Need information on '98 1 ton 4WD front hubs and suspension [Re: Hemi_Joel] #2476839
04/03/18 04:11 PM
04/03/18 04:11 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
This is what I would do as well.
Once you go through the king pins, bushings, shocks, and brakes, you will be $ ahead.
Those old trucks handle just fine.
It will last for many miles and years.
I have mechanical Aptitude.
I can screw up anything.
