This topic has come up a few times in the past:
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/190879/re-440-intake-heat-shield.htmlFWIW, the consensus is that they are not really a heat thing, more for sound deadening. And when you think about the fact that the heat riser is already running through the center of the intake manifold, it kind of makes sense.
And FWIW the factory called it a "valve tappet noise reduction package."
I saw a 72 service manual with a description of the pad in it, so they went at least that late. How much after that I do not know...
